Lechler sparkling glass base coat
Home / Forums / Main Forum / Introductions / Lechler sparkling glass base coat
  • April 4, 2013 at 2:11 am #42575
    Anyone used this? Found it to be a good match for vw scirocco/passat wherls depending on ground coat used
    I have trouble with scratch marks showing through the base coat!! Even if i wet flat with 1200nd finish with p3000 they still show 🙁
    Any helps/tips much appreciated!
