Liquid Masking
Home / Forums / Main Forum / Paint and Refinish / Liquid Masking
- This topic has 20 replies, 12 voices, and was last updated 15 years, 3 months ago by brandon dingwell.
- September 15, 2009 at 6:25 pm #15920
Are any of you guys using a form of liquid masking? I need some imput on some of the products out there.
AnonymousSeptember 15, 2009 at 7:06 pm #15921We are currently using plastic but at a previous shop we used a product called slime, might have been by 3M. It was pretty good anyhow.
[b]jimmo wrote:[/b]
[quote]We are currently using plastic but at a previous shop we used[size=5] [b]a product called slime[/b], [/size]might have been by 3M. It was pretty good anyhow.[/quote]3M Slime now there is a blast from the past i used to use slime in the early 90’s bit of a novelty product tried it for awhile but went back to wondermask polethene
September 16, 2009 at 3:48 am #15938i have the stuff from AFS. company i used to get my booth filters from. put a link below. it reminds me of dawn dish soap. even smells like it. i would use it as a booth coating. i reduce it 50% with water and after we clean the booth and the walls are dry i spray a coat on. it dries and when we wash the booth out everything just melts off the walls leaving it bright white again. works really well. i have a 55 gal drum of it here. i figured it out and at the rate i use it that will last me aprox 12 years. :lol1
http://www.afcfilters.com/pc/index.html
[b]jim c wrote:[/b]
[quote]i have the stuff from AFS. company i used to get my booth filters from. put a link below. it reminds me of dawn dish soap. even smells like it. i would use it as a booth coating. i reduce it 50% with water and after we clean the booth and the walls are dry i spray a coat on. it dries and when we wash the booth out everything just melts off the walls leaving it bright white again. works really well. i have a 55 gal drum of it here. i figured it out and at the rate i use it that will last me aprox 12 years. :lol1http://www.afcfilters.com/pc/index.html%5B/quote%5D
wow, that’s an idea I’ve never heard of. What do you apply it with on the booth walls?
I use spray mask and love it. The 3M stuff is high dollar but tons of people sell the stuff. I’m using the spray mask from Keystone now and it works great. Finishmaster has been sending me gallons of the stuff for free!!! Some new promo brand called Smart. As far as the spray mask overspray…it does get on everything. I just spray mask the jobs when I get them from the bodymen then use a water-based cleaner to wipe off the panels I’m painting. DX394 from PPG works great for this. Don’t be fooled though. If you spray your paint or clear directly on the spray mask it will bleed through. I always use 36inch paper for masking.
September 16, 2009 at 9:12 am #15954wow somtimes u guys really amaze me with all ya know about different products on this site :blink: keep it up…cool stuff
I just use an old paint gun to spray the stuff on. Don’t use any of your good guns, the stuff is really hard on all the guts of the gun. Still have to mask everything like normal. It is simply a replacement for plastic sheeting. When you’re done with the job, just powerwash it off.
September 18, 2009 at 4:01 am #15991on the booth walls i just spray the stuff. like i said this product is blue and looks just like dawn dish soap. actually i swear thats what it is. anyway with my booth being white i dont want to turn the walls a blue color so i thin the stuff out 50/50 with water and spray a thin wet coat on with my lph400. that sprays it thin enough where its basically transparent. i go right over the glass on the lights and everything. you cant even tell its on there but washes off great. takes me about 15 minutes to do the whole booth but saves a ton of labor cleaning it and the walls always look brand new. between that and the white booth paper for the floor that i started using the booth always looks brand new and is super bright all the time.
hey maybe instead of water on the floor which is unfavorable with water born :pcorn: The real Spraymask ( a thick film not dish soap) was and is used for airbrush work but dries and can be cut and pulled out :pcorn: this stuff is in fact more of a boothcoat / dish soap :pcorn:
