lvlp guns?? or iwata w400
Home / Forums / Main Forum / Paint and Refinish / lvlp guns?? or iwata w400
- This topic has 10 replies, 4 voices, and was last updated 13 years, 3 months ago by raymond.
- September 2, 2011 at 12:43 am #32702
hi there, i’m new to this forum and spraying and am lookin for a new clear gun and have seen lvlp guns. anyone use these? has anyone any experience with the sharpe razor lvlp or the daltalyo lvlp guns? if not what would you recommend? i was thinkin iwata w400 classic (lv2 cap)? or are these air hogs?
September 2, 2011 at 3:53 am #32708[quote=”paintbreaker” post=22222]i am iwata’s w400 lv2 user..i love my gun..i only use for clear..fine atomizing..minimize orange peel..w400 is one of the famous clear coat gun[/quote]
what sort of psi and cfm? i only need to spray panels and bumper and have a 100 litre compressor.
September 2, 2011 at 12:47 pm #32720what cap are you using paintbreaker? lv2?
this is the gun i want and comes with lv2 but runs at 2.0 bar which is 29psi
http://www.spraygunsdirect.co.uk/product.php?products_id=2167
so any experience with lvlp?
i using lv2 cap..lv4 cap is only for w400lv compliant gun and hvlp gun. u must check the noozle also..make sure got mark ‘w400’
make sure u receive your spray gun like this:
http://www.asetusa.com/phpBB3/viewtopic.php?t=162September 2, 2011 at 10:40 pm #32726wouls u consider the w400 lv2 a good gun for clear? does it require much air and does it layer the clear nice and flat? would you recommend a 1.3 or 1.4 tip? cheers
w400 is old model before w400lv (compliant gun)..the different is air cap and nozzle. if u want to convert w400 to w400lv just change lv4 aircap and change the nozzle. the famous iwata’s clear coat gun is w400/w400lv. w400lv inlet pressure is 20psi..so can less overspray and save your paint. w400 inlet pressure is 29psi. if you have more budject i recommend w400lv..if not u can go with w400. dont worry because u can convert your w400 to w400lv..just change air cap and nozzle. my suggestion is 1.4 tip for clear coat. myself also using w400 with no problem..atomizing very fine..im loving it
:dnc - AuthorPosts
