mitchell Collision Guide – Unibody & Chassis
Home / Forums / Main Forum / Paint and Refinish / mitchell Collision Guide – Unibody & Chassis
  • December 27, 2009 at 3:22 am #18321
    hi i need to know if anyone uses this book or program or atleast something similiar.
    i just need the guide for a
    91 nissan 240sx
    for the driver side rear quater panel.
    im trying to get a quater panel back to factory spec.
    thanks alot! 😉
    link
    https://www.mitchell.com/mitch/products/product.asp?pf_id=34
    December 27, 2009 at 6:42 am #18326
    i would have thought it would be a fairly average time between 20-25hrs this would include a one way blend into the door.
    If you were blending into bootlid/decklid and rear bumper there would be additional time for this as well.
    also not sure if the quarter glass is bonded on this model, there would be an opinion time entered here as well.
    most estimating software assumes you are re-finishing the vehicle to close factory spec.
    nick
    December 27, 2009 at 8:07 am #18330
    thanks alot
    and the quater glass needs to be taken off so it might take a few more hours for that.
    is that just for estimate time?
    do you have a diagram for it? (rear quaterpanel and rear tail light area)
    89-94 nissan 240sx fastback 3dr
    December 27, 2009 at 8:10 am #18331
    its for this type of damage
    [img]http://i50.tinypic.com/2qs7zmc.jpg[/img]
    December 27, 2009 at 8:00 pm #18343
    i dont get it, why do u need a diagram for that? is the diagram for replacing it? because in that case just take your time and eventually ull discover each spot weld that holds it in place. vehicle construction is quite standard with a few exceptions so after a couple of jobs youll have the techniques memorized for removing and installing parts that diagrams will become comical for you. but if your looking to repair it, from the looks of the photo thats basic body work, you can use the other side as a guide to duplicate contours and lines.
    December 27, 2009 at 9:46 pm #18345
    [b]airhead wrote:[/b]
    [quote]its for this type of damage
    [img]http://i50.tinypic.com/2qs7zmc.jpg[/img][/quote]
    That one needs a little additional time on the bench, needs a little pull to close that gap on the quarter to decklid. And their is probably a little localized damage to the inner quarter and rear light area.
    the bonded glass removal is only gonna be worth about 1.5hrs.
    all in all if you pressed all the right buttons and squeezed the estimate for every dime you could maybe get around 30hrs. In the real world that would total a vehicle of that age in the UK.
    [b]p.s. sorry i should read the post’s more carefully :wak it would appear you want a diagram for replacement procedure and not the time factor involved.[/b] :blush: :blush:
    December 27, 2009 at 10:52 pm #18347
    ya the mitchell wont tell ya any details on it just how long it will take
