motorcycle paint formulas
Home / Forums / Main Forum / Paint and Refinish / motorcycle paint formulas
- This topic has 9 replies, 7 voices, and was last updated 13 years, 7 months ago by Scott.
i have a 2007 kawasaki zx6r and the paint code is 234 passion red. how do i go about finding a formula for that with color pro? or in general i dont see oem motorcycle companies listed in the program so how do you retrieve a formula for motorcycle paints? thanks
March 20, 2012 at 1:13 am #36390see. should have went with PPG instead of that Wanda broad :p :rofl :rofl :rofl
March 20, 2012 at 2:02 am #36392the ppg code is 911264. if color pro has an option for looking up competitor codes try that. if not, it’s a solid red. should be able to find a chip in the deck that matches pretty close
March 20, 2012 at 3:36 am #36393You can either look at your color map book to match it up or phone the color lab in atlanta and they will send you a formula,or buy some ppg.
March 20, 2012 at 3:36 am #36394Mo, call the akzo tech line (or have your jobber call) and give them the code and get an akzo code for them or a colormap number. If you get an akzo number look it up on line with their mixit online. http://www.qnetonline.nl/SIKNA/SearchForm/Manufacturer After you find it, click “documentation” out to the right and it will pop up the colormap number.
Or you could get them to just give you a colormap number and then look it up through colorpro. The colormap numbers are the same ones in sikkens.
That is the thing about wanda, if they list the code in sikkens (and not in wanda) you can pull it up via the sikkens colormap code. I do this all the time for the old car colors as the wanda database doesn’t hold a lot of them in the program. I just pull them up through sikkens and get the colormap code and then pull it up in colorpro.
They are the same books in Sikkens, Lesonal and Wanda (not sure about utech).
March 20, 2012 at 5:22 pm #36408FYI, Sikkens has motorcycle chip books. You just have to know the right people.
I personally would not trust a colormap chip to cross to a motor color. Ballpark yes, match not so much.
Like Jeremy said, call ATL. 1-800-618-1010
March 20, 2012 at 6:11 pm #36412I just checked color pro at the shop and they do have kawasaki colors. Listed under “kawasaki motor” same with honda under “honda motor”.
Whether or not they have that color I don’t know…theres about 6 reds that pull up. They don’t have as many codes listed as sikkens.
