Mottle in my blends
Home / Forums / Main Forum / Paint and Refinish / Mottle in my blends
- This topic has 4 replies, 4 voices, and was last updated 12 years, 7 months ago by Jayson Munro.
Hey guys. Started working in a shop that uses debeers 500 paint. Lately I’ve been having troubles with mottle in my metallic blends. Full panels are fine. I spray a wet coat then reduce pressure and do a drop coat and lays down fine, but when I do my blends I’m finding it mottles. Anyone have an advice to stop this happening?
Oh I do put down a clear ground first but still sits up.
Thanks for any advice or tips and tricksMarch 2, 2014 at 5:50 pm #46014When are you doing your drop coat? Debeer likes the drop coat done right before your base flashes. Dont let it dry first like most bases.
March 4, 2014 at 4:35 pm #46028[quote=”Tricks” post=34601]Yeah I drop coat just before it flashes off but the mottle is on the edge of my blend when I flick it out where it’s a little dry[/quote] Instead of flicking it out at the edge I angle the gun inward and feather the trigger from air only to full fluid as I come in toward the repair. I seems really weird at first but after a while it becomes simple. When done correctly this will eliminate the dry edge.
March 5, 2014 at 7:21 am #46037Use slow reducer and flick your arm and wrist like you are trying to start a lawnmower :rofl Sounds dumb but it works…..If your reducer is too fast it will dry in the air before it hits the surface.
