My first respray
Home / Forums / Main Forum / Gallery / My first respray
  • April 8, 2011 at 4:06 pm #30217
    Well i turn first year in November of this year but i have been spraying on and off for 2 years now as an apprentice, Ive done alot of bumpers / panels / blends but not many full resprays so i decided to do my own car, i just got a friend to do the bog work then i 2k primed it, blocked it, buzzed it, stripped the whole car, rubbed it down etc and painted it, I also removed the stone guard from the doors, fenders and the sill panel, 2k primed it and blocked it smooth.
    The gun i used is a Satajet 3000 Foose Edition
    The basecoat is PPG Ford Ego
    The clear coat is Debeer on front end and Valspar on rear ( i ran out half way through and they didnt have debeer in stock at the time )
    The compressor is only 2.5hp, 17l/Min
    I did it at home in my shed
    So, What do you think? One mistake i made was leaving it for 2 weeks before cutting / buffing, and i didnt get it completely flat of the gun, it was a it hard with the inconsistency of air pressure due to using such a small compressor.
    April 8, 2011 at 4:10 pm #30223
    And did i mention i removed the rear wing and bogged up the holes, i should have got them welded but couldent be bothered, 1 of the holes has slightly sunk back but anyone whos not a painter will not notice this.
    Oh and some pics of it completed and put back together.
    April 8, 2011 at 7:56 pm #30229
    Looks good. You can only get better as long as you remember your mistakes and not repeat them
    April 8, 2011 at 10:41 pm #30234
    Looks good! If you’re willing, you can sand (P400/P800) and shoot 3 more coats of clear.
    My old Z32
    [IMG]http://img.photobucket.com/albums/v345/zsolo/Zride/0a7e378d.jpg[/IMG]
    [IMG]http://img.photobucket.com/albums/v345/zsolo/Zride/3b50a535.jpg[/IMG]
    Sexy ride…:)
    April 9, 2011 at 5:25 am #30239
    Yeah i was thinking of re clearing the entire car, would clear fill up 500 grit if i skim back the clear with 500 grit on the air sander with a soft pad? or do i need to go from 500 upto wet 800 before clearing again?
    April 9, 2011 at 6:27 am #30243
    That’ll work. But 800 alone is good enough and you’re less likely sand through. Anyhow, you’re done for now. Drive it!
    April 9, 2011 at 7:31 am #30246
    As a guy that paints in a shed – I appreciate how hard it is to pull it off and make it look as good as you did. Great work.
