My Make Shift Paint Area
Home / Forums / Main Forum / Gallery / My Make Shift Paint Area
- This topic has 10 replies, 6 voices, and was last updated 14 years, 5 months ago by Rick Hiott.
- May 17, 2010 at 7:37 am #21292
Just wanted to show you guys what I have been working on. Took half of my garage and made a place to paint small jobs in at home. I need to do a few tweeks on it but it works pretty good for the most part.
http://i912.photobucket.com/albums/ac327/daveclark236/Paint%20abooth/027.jpg
http://i912.photobucket.com/albums/ac327/daveclark236/Paint%20abooth/029.jpg
http://i912.photobucket.com/albums/ac327/daveclark236/Paint%20abooth/008.jpg
May 17, 2010 at 4:51 pm #21298Fan for fresh air is a squirel cage mounted up top. Exaust is a louvered farm fan from Tractor Supply. Its just a little on the small side but it does pull the overspray out. I have more positive pressure than neg.
May 17, 2010 at 7:27 pm #21300Thanks for the info,I have been looking at the fans at tractor supply what size are you using?
May 18, 2010 at 5:49 am #21306[b]lethal6 wrote:[/b]
[quote]What are you using for a fan? Great looking space.[/quote]Its a Maxxair Heavy Duty 14″ 1/8 HP. Flows 1400cfm. If I were to do it again I would step it up to the next size. 18″ 14 hp 3000 CFM. These fans are easy to install and seem to be built well.
May 18, 2010 at 9:43 am #21310That is a very nice set up for a home booth,I bet it will work awesome.You could always build a wall and make it permanent.Thanks for sharing 😉
May 19, 2010 at 7:26 am #21338[b]Jayson M wrote:[/b]
[quote]That is a very nice set up for a home booth,I bet it will work awesome.You could always build a wall and make it permanent.Thanks for sharing ;)[/quote]Thanks Jayson! I have thought about putting up a wall. Im very limited on space and having a wall down the middle of my garage would just make it too tight. If I had the room it would be done 😉
July 5, 2010 at 6:26 am #22322It looks good,,,but I would add more lights. You can never have enough………
