my putty marks raise after paintjob
Home / Forums / Main Forum / Auto Body Repair / my putty marks raise after paintjob
  • June 4, 2011 at 11:57 am #31116
    Hello friends,
    good day to all
    im from Pakistan. i dont know standard terms name for body repair elements but i will explain my case in simple words.
    on my very first DIY i have modified my 82 Honda Accord myself. i replaced the front bumper with 98 Corolla bumper and the rear one with Suzuki Baleeno. i used very cheap conventional gun for spray. i used habanero red( honda City shade) though my first project did fine but one thing really confused me.
    here in Pakistan we apply steel putty to surface then we apply primer to it and then soft putty called deeko putty is applied for minor dents. and finally we apply the primer and then paint. i did the same but i noticed that my putty parks have been raised after paint job( on back bumper). any expertise
    regards
    kuki
    June 16, 2011 at 8:25 pm #31247
    What kind of putty and primer?
    Sounds like the putty is absorbing solvents.
    Use only putties that need a hardener and
    use only primers that use an activator (hardener).
    Otherwise you’ll have shrinkage issues, not swelling.
    Hard to say without knowing your products.
    July 10, 2011 at 7:31 pm #31628
    [quote=”JCClark” post=20871]What kind of putty and primer?
    Hard to say without knowing your products.[/quote]
    thank you clark for your reply.
    in fact i have not use either of material.
    what i use and how i use is as follow.
    first i used the putty which comes with hardener.then i sprayed a cheap primer which did not need hardener.then i adjust the body with a soft putty which dont need hardener. then sprayed the same cheap primer.and finally paint and immediately after that clear
    now as days are passing i am noticing the some marks are bulging out but some are going inside.
    i just want to know what causes these two phenomena.
    July 10, 2011 at 8:47 pm #31631
    Im going to say that all your problems stem from putting to much wet product over each other to fast with no flash times. Also you should be using putties and primers with hardener in them this will also help you in the future. But we all had to learn somehow and your giving it your best. Try some new products and see if it doesent help. practice on something first.
    July 11, 2011 at 5:43 am #31635
    all that stuff you are using that has no hardener is junk and is just soaking up the solvents. it will always shrink back and dull if you are using products like that.
    July 11, 2011 at 5:48 am #31636
    if ya give all those things a good rest for a day or 2 then use a enamel 1k sealer it will help ur soaking problems alot nothing wrong with all the 1k crap if ya know its place ive seen better jobs done with it when used right than some jobs with 2ks when they were used an abused 😉
    July 11, 2011 at 7:36 am #31637
    i am learning from you all.you all game me new things to remember for better future.but i am still confused that why some putty raised like bubble and some shrink inwards.can some one explain these two happenings.
    July 11, 2011 at 7:50 am #31638
    Jim C told you why this was happening just read the posts :teach
    July 11, 2011 at 8:52 am #31639
    [quote=”Wydir” post=21223]Jim C told you why this was happening just read the posts :teach[/quote]
    it only describing the shrinking
    all that stuff you are using that has no hardener is junk and is just soaking up the solvents. [b]it will always shrink back[/b] and dull if you are using products like that.
