nason clear
  • November 5, 2012 at 5:20 am #38912
    just moved to a shop and i’m spraying nason’s clear(465-00)85 hardner and using dupont 95 reducer.booth on 85.hazing up and i need some advice.
    November 5, 2012 at 6:39 am #38913
    you’re not using DuPont basemaker in the clear are you :blink:
    November 5, 2012 at 10:55 pm #38918
    I believe that clear mix ratio is 4 to 1 mix with NO REDUCER.
    November 6, 2012 at 12:23 am #38919
    Thats the 498 that’s 4:1. The 465 is 2:1:20%.
    November 6, 2012 at 5:29 am #38921
    You are useing the wrong reducer acording to the dupont web sight it say’s to use 20% Ful base 441-21 or 441-22 reducer. Some time different reducer cause trouble even with the same parent company. I have seen this happen before but if you color sanded and waited until the next day and buffed it out the haze was gone. I have seen this happen also when the fans were turned off before the solvent evaporeted and it settled on the top panel (hood roof deck lid)
    Just my 2 cent worth
    davidj1950
    November 6, 2012 at 7:29 pm #38922
    We have been spraying this clear for a few years now & it is a really good clear. Great gloss and durability, easy to buff. We spray around 75 degrees F & have found that a combo of 75% mid temp and 25% high temp activator works well. And even though it says 20% reducer we go 25% because this clear is so thick. Try it out, works great for us. Only thing I have noticed is that if the clear is buffed the same day as being painted- then put out in the hot sun, some of the sand marks can reappear.
    November 6, 2012 at 7:32 pm #38923
    Mid temp activator 483-84, High temp 483-85. Reducer is nason 441-21
    November 6, 2012 at 7:44 pm #38924
    Not a bad clear. How long do you give the basecoat to dry? How long between coats of clear?
    November 8, 2012 at 5:38 am #38975
    no
    November 8, 2012 at 5:48 am #38976
    [quote=”jasonsdream” post=28075]no[/quote]
    :blink:
