Need advice on painting chrome bumpers
Home / Forums / Main Forum / Paint and Refinish / Need advice on painting chrome bumpers
- This topic has 15 replies, 11 voices, and was last updated 11 years, 9 months ago by Rob van Abeelen.
- July 7, 2013 at 7:11 pm #43556
Unfortunately the only way to have a chance for it to last is to sand blast them,epoxy and paint.Just sanding them is a redo waiting to happen.Getting one of these and a couple bags of sand is much cheaper than a redo http://www.harborfreight.com/40-lb-pressurized-abrasive-blaster-68992.html Good luck
July 8, 2013 at 1:54 am #43558I have had success, but only on a smallish grille insert which was chrome plated plastic (not sure how they do that). My method might be a bit cumbersome for a full size bumper, scrubbing a hydrochloric acid wash with a red scotch pad. Then a thorough water rinse and on with U-Pol Acid #8 etch primer in a spray can. Seems to have stuck pretty well.
July 8, 2013 at 6:54 am #43563I’ve had a lot success sanding the chrome with 220 make sure there’s no shine spots, then spray etch primer, seal and base. Or etch and prime.
Actually just finished a 2013 f350 guy wanted all chrome trim pieces painted to match. Also did 2010 Maserati all the chrome trim and wheels. Guy curbed checked the wheels about 6 months later and the paint held up good didn’t peel back.Attachments:July 9, 2013 at 3:51 am #43567Keep in mind if you have gravel roads in your area or a tough environment sanding and etch will not last.
[quote=”Jayson M” post=32324]Keep in mind if you have gravel roads in your area or a tough environment sanding and etch will not last.[/quote]
I think here in Alberta, you might only get 6 months out of it if you are lucky.
The odd one we’ve done here, we’ve sent to the chrome shop to have the chrome stripped off.
After having a conversation with the customer that was largely based on the information and advice in this thread, he has asked me to sand the bumpers as best I can, etch, prime, base, and clear. There was a lot of rationalizing going on, “The car won’t get driven much, it lives in a garage, etc…”
Hopefully, the job holds up well. I’ll post pictures once it’s done.
