need help with gun
Home / Forums / Main Forum / Paint and Refinish / need help with gun
  • June 14, 2012 at 12:36 am #37161
    Hi im new to the forum its really great. im having trouble setting my gun up its a hvlp sharpe finex 1.4 tip i just did a spray test on some masking paper and its putting more material on the upper part of the fan pattern how do i get a nice and even pattern? its currently set up 40 psi i set the fluid knob all the way out held trigger turned in till the trigger moved out a bit and my fan is set pretty wide.if anyone can help im a noob and i want to get it right before i paint my car thanks.
    June 14, 2012 at 5:26 am #37186
    Did you try breaking down the gun and cleaning it? fluid tip or air cap may be dirty
    June 14, 2012 at 5:28 am #37187
    try turning down the air pressure some 😉
    June 14, 2012 at 7:23 am #37188
    have ya tried turning the aircap upside down ta see if it changes ta bottom heavy yet?? sounds like ya got some buildup where ya shouldnt 😉
    June 15, 2012 at 3:20 am #37193
    i think this gun should be running at around 30psi
