Need some help guys
Home / Forums / Main Forum / Auto Body Repair / Need some help guys
  • January 26, 2011 at 2:05 am #27617
    Hi guys
    I just got a waterloo box. I need to take out 1-2 drawers out to put the wheels on. This is where im stuck on how to get the drawers off the rails.
    January 26, 2011 at 2:50 am #27618
    When the drawer is pulled out can you see a black plastic piece in the slide?
    January 26, 2011 at 3:43 am #27619
    Theres a slot and in the slot like part of the rail that sticks up alittle.
    January 26, 2011 at 4:09 am #27620
    Like Ryan said, there should be a little plastic piece (usually black)..basically a tab that you push down or up to slide each rail out. Is there not a little instruction sheet with the tool box?
    January 26, 2011 at 4:20 am #27621
    ben i looked at the instruction book and it shows a slot were you suppose put a screwdriver thru.
    January 26, 2011 at 4:25 am #27622
    just weld them on :clappy
    January 26, 2011 at 5:18 am #27623
    tool box ……:rofl ……. oh hell just leave your tools all over the shop like the Pro’s :whistle:
    January 26, 2011 at 5:52 am #27626
    [quote=”bodymanhelper” post=17543]ben i looked at the instruction book and it shows a slot were you suppose put a screwdriver thru.[/quote]
    Ok, so you have the basic (non bearing) sliders, correct?
    If so, there should be an oval hole. Push in the metal in the oval hole with a hard screw driver. It will take a good bit of force. At the same time, pull the drawer and hold the slider. Repeat for the 2nd side. It isn’t too hard, but does take some effort. :cheers
    January 26, 2011 at 6:42 am #27628
    ben i have the ball bearing sliders.
    April 6, 2011 at 8:48 pm #30174
    Cant figure out how to take your tool box drawers OUT????
    WOW?
    April 6, 2011 at 8:49 pm #30175
    [quote=”Stone” post=17545]tool box ……:rofl ……. oh hell just leave your tools all over the shop like the Pro’s :whistle:[/quote]
    Thats the way its done isnt it?
