Newbie help with body filler on body lines
Home / Forums / Main Forum / Auto Body Repair / Newbie help with body filler on body lines
  • January 30, 2015 at 7:18 am #48199
    I am new to body work, and I have a job to do on one of my personal vehicles, a small dent on the body line on the front fender of an 08 mustang. I’m looking for any suggestions on the best way to get the body lines perfectly straight again. Any ideas would help out tremendously. Thank you all in advance.
    January 31, 2015 at 5:13 pm #48206
    It’s the side line mid height on the fender that goes from the fender through the door.
    February 1, 2015 at 5:01 pm #48212
    That is good advise. Masking tape, guide coat and pencil lines can be a great help especially on difficult body lines and contours.
    Once you have the repair in primer and blocked out I spray some wax and grease remover / panel wipe over the area and look down the panel to check for straightness. If your not happy with it, rework it otherwise it will show once painted.
