Not Grandpa’s Buick
Home / Forums / Main Forum / Restoration / Not Grandpa’s Buick
  • May 6, 2011 at 3:48 am #30715
    Thought I would share some pics of a car that I have been working on for 10 years off and on. It is a 1986 Buick Regal T type, 3.8l V6, turbocharged and intercooled. Driveline is all new and the body has been stripped to the factory sealer, lower door skins, inner and outer have been replaced, very little rust on the rest of the car. Filled the power antenna hole, hood emblem in the header panel, did away with all emblems and bodyside mouldings. Looks a whole lot cleaner now. It is an original white car, that has been painted with a tri-stage white, Mitsubishi code w13, and top coated with some Omni MC 270 clear, 4 coats wetsanded smooth and then recleared with 3 more coats.
    Heres some pics, let me know what you think
    May 8, 2011 at 7:56 am #30750
    looks good, I heard those turbo v6’s pull pretty hard:cheers
