Paint code for a Ferrari? cant find it on car?
Home / Forums / Main Forum / Paint and Refinish / Paint code for a Ferrari? cant find it on car?
  • August 31, 2009 at 8:22 pm #15607
    Thanks guys
    So far no calls
    August 31, 2009 at 9:27 pm #15609
    I have been given this on another forum
    Giallo FER 102 and is a single stage Glasurit
    Any one know if it is correct?
    I have to find a Glasurit dealer in my area
    August 31, 2009 at 9:35 pm #15610
    The paint code codes up as 102 – FER is just the abbrev for Ferrari, not part of the paint code itself from what I can tell. The color they call it is GIALLO MODENA. It’s available base/clear, singlestage, waterborne. You should be able to use whatever you want over it.
    August 31, 2009 at 9:36 pm #15611
    solid colors like white and yellow sometimes are singlestage :huh:
    August 31, 2009 at 11:06 pm #15613
    Hi Guy’s
    Yes its a single stage and I need it in a single stage as well too match the rest of the car.
    I have been talking too BASF and a Local finishmasters for it no luck so far from Finishmasters BASF said to order it from a shop in Minnesota god only knows how much that will cost with shipping.
    Any way code is 102 available BASF # 558929 in Gasurit 22 line can any of you guys that run the Glasurit line mix it? I only need a qt.
    That probably more than I need even
    Also how hard is this stuff to blend in?
    Can I Scuff and buff the stuff?
    August 31, 2009 at 11:19 pm #15614
    I can Order it premixed from my jobber & would normally help u out but I’m on holidays the next two weeks and won’t be in town as of tommorow.
    August 31, 2009 at 11:21 pm #15615
    It will blend the same as clear. Ideally your could apply you first coat halfway through then cap the entire panel with straight clear.
    August 31, 2009 at 11:30 pm #15616
    Looks like 102…
    Edit: oh you already got it.
    August 31, 2009 at 11:41 pm #15617
    [b]Doright wrote:[/b]
    [quote]I have an 81 Ferrari 308 GTSI in original yellow paint.
    I need a Paint code My jobber says to match the paint color.
    I cant find any thing on car.
    No tags like on vetts that lists color code, Trim code etc…
    Any one have any idea as too were I might find it? or does any one have a book that may list it?
    Also Car appears to be painted in a Single stage?
    Would it be a single stage?[/quote]
    Thanks we will see what the Vegas dealer says shortly
    September 1, 2009 at 2:07 am #15622
    finishmaster cant mix you 22 line
    September 1, 2009 at 2:17 am #15623
    there is a formula for 102 in uno as well (rm’s ss). you should not have to order it special. just about any basf jobber should be able to mix either 22 or uno for you right there.
    September 1, 2009 at 2:58 am #15624
    Yah go head and blend it out just like bc/cc like jimmo says
    :pcorn:
    September 1, 2009 at 7:11 pm #15633
    Jim & Ding
    No Finish Master cant blend it in 22, UNO or RM no Toners available all dried up he says. just my luck. :S
    Seams every thing My FinishMaster gets is out of CA and AZ and CA is all Water base now pretty much.
    I found guy in Minnesota that will do it in 22 for me 140 qt plush shipping :unsure:
    Stone
    Thanks for the info
    September 2, 2009 at 1:02 am #15640
    My cost on 22 line is $120 and for Uno is $64. I can get you a quart and ship it out. you would need to get the hardener and reducer on your end. PM your address if you want
    September 2, 2009 at 9:44 pm #15649
    Ding
    I will take it I sent you a email through the board I dont know if you got it
    My number is
    775 727 1964 h
    775 513 8814 cell
