Paint flaking off masking plastic while spraying?
Home / Forums / Main Forum / Paint and Refinish / Paint flaking off masking plastic while spraying?
- This topic has 8 replies, 6 voices, and was last updated 13 years, 8 months ago by daniel rivera.
- August 7, 2011 at 9:56 pm #32151
Y does paint flake off masking plastic ..some times even while painting ..im new to auto refinishing. Lets say im going to spray a side of a car ..can I mask the rest of it with just masking plastic and tape? With out using no paper. But will paint flake off while I spray?
August 7, 2011 at 10:19 pm #32152Only the cheap non automotive plastic has this problem,but back in the 80s when plastic was first being used it was an issue.If you use a name brand like norton,carbo,usc or 3m the plastic is marked paint this side.It is a non issue in this day and age. You mask the jambs,cover the vehicle with plastic,cut the plastic where you are painting and tape down the edges,no worries.
you could also cover 24 – 36 inches around your spray area with paper and then plastic the rest and tuck plastic under the paper just for some extra protection. Before i used to have the occasional problem with some paint flaking off of the plastic during the bake cycle, if im rushing I may just use plastic but i usually like to put paper around spray area just so im not painting directly onto the plastic.
August 7, 2011 at 11:01 pm #32155like jayson said. Make sure that the side marked “this side up” or “paint this side” is actually facing up. otherwise you will have problems
[IMG]http://i288.photobucket.com/albums/ll186/paintbyding/MVC-226S.jpg[/IMG]
[IMG]http://i288.photobucket.com/albums/ll186/paintbyding/MVC-229S.jpg[/IMG]
August 7, 2011 at 11:16 pm #32157And again, I’ve never had a problem painting right up to modern plastic, as long as it’s the right way around.
Keep the plastic nice and tight though. It’ll stop it flapping around which will reduce the risk of flaking even further, and it won’t stir up the dust as much either 😉
August 8, 2011 at 6:20 am #32178Yea man no worries, right side up and decent tape you are golden.
However, you can get flaking when unmasking. This can have equally bad results.
August 8, 2011 at 6:40 am #32179I guess I have to be careful unmasking with plastic masking..good to know .thanks
