Paint Guns
  • May 22, 2010 at 4:48 am #21440
    Hi Friends
    Iam a beginner. Iam looking for a Paintgun what consideration should be have for primer, paint and clear?
    Thanks
    chelo2003
    May 22, 2010 at 9:23 am #21446
    welcome, I like sata spray guns, you get what you pay for. Sata 3000 HVLP for base and clear. Have older sata 2000’s for primer and sealer. I have 8 Sata’s, 2 devilbiss GTI’s. You can probably get buy with a cheaper primer gun. Spraying base and clear, a good gun will make your life easier and your jobs look better.I started with a Bink’s #7 and a Devilbiss JGA…LOL..showing my age :exci
    May 22, 2010 at 4:43 pm #21458
    Thanks The Vilvis Gun are enough good for make a good paint?
    May 22, 2010 at 6:13 pm #21460
    Yes, if you are new, ask your paint jobber/supplier to lend you a demo gun. You can use that for free and see how it sprays. If you are new,have someone with experience go in there and help you get started, another painter there or a paint tech from your supplier. That will go a long way. Mistakes happen and its all part of learning.Having someone with experience with you, can get you going in he right direction and make you feel more comfortable with spraying distance, air pressure, and how much material to apply to the surface you are painting. Happy Painting !!
    May 22, 2010 at 8:27 pm #21477
    Thanks I will do.
