painting car same color
Home / Forums / Main Forum / Paint and Refinish / painting car same color
- This topic has 7 replies, 6 voices, and was last updated 12 years, 10 months ago by Don Wedor.
- February 1, 2012 at 3:02 pm #35668
hey guys im contemplating whether to paint car myself or pay to have it done. i have never painted a car before so i would appreciate honesty.
im painting same color (black) i have fairly large areas of clear coat deteriation. should i sand these spots to the metal then prime.
ive never done this before and i cannot afford a $1000-$1500 paint job.it seems no one will answer my questions. if you can help i would be very greatfull. thanks keep up the great workFebruary 1, 2012 at 9:34 pm #35670If you’ve got someone that’ll respray your car and do a decent job for that 1000-1500 price range, jump on it.
You’ll easily spend that much and more acquiring tools and equipment to do it yourself.
What tools do you have now?
do you have a space to paint this car?if you have all the tools already
and all materials like sandpaper, tape , masking paper , cleaners and you just need to buy the paint then you will be close to 300-500 for just paint and clearcoat
If you go to a local paint supply store maybe one that sells PPG Omni/shopline paint and just ask what for some prices to get an Idea. it can be any paint supplier does not have to be PPG can be Dupont , heck Kirker , Summit racing , all kinds of paint out there should be able to find some thing in your price range
1 gallon of primer
hardener for primer
depending on size of car may need 1 gallon of basecoat (if its a solid color look at a single stage paint then no need for the clear coat ) you said it was black but didn’t say if it had any pearl or metallic in it
1 gallon Reducer for basecoat
1 gallon of clear coat
hardener for clear coat
1 gallon of Wax and grease remover , 1 gallon of acetone for clean up of tools You probrably could get away with just a quart of these itemsFebruary 2, 2012 at 3:42 am #35676You left out the most important item; “the know how”, I think you be better off if you have the car painted, it’s gone to cheaper at the end.
February 2, 2012 at 5:28 am #35680[quote=”Wydir” post=25018]well you got to learn somehow how are people supposed to learn anything when all your advice tells them to have someone else do it.[/quote]
I’m all for learning through the DIY route…..but most all people don’t learn to swim when pushed into the deep end!
Suggest if the OP really wants to paint, he/she start small and practice on some test panels. Even then, it’s a big step up from painting a panel to an entire car!
February 2, 2012 at 6:51 am #35684if you want to learn because you think you might like doing this, thats great. but if you want to do it just to save $1000 it aint gonna happen
[quote=”ding” post=25023]if you want to learn because you think you might like doing this, thats great. but if you want to do it just to save $1000 it aint gonna happen[/quote]
:agree This is not a job you will get right the first time. no matter how much practice. Until you spray the whole thing. that is how you gain the experience to build on.
I guess you could just use a paint roller and some tractor paint , can have your car painted for under 100.00 (just a tip use a foam roller)
