Panel Bond / Cure Speed
- This topic has 2 replies, 3 voices, and was last updated 18 years, 5 months ago by .
Home / Forums / Main Forum / Auto Body Repair / Panel Bond / Cure Speed
I’m just curious to hear some opinions, I have one of our techs about to panel bond on a quarter to a 99 grand am. His plan is to use the norton super fast urethane which gives a 10 minute work time. I wonder why the need to use such a fast adhesive, I’ve always seen most guys use the 6115, 90 minute stuff. Is this gonna dry before its even on, what are your thoughts?
That is pretty fast but if the area is not too large it should work fine.Just does not leave a very big window if you run into problems.
10 minutes to stick it on and clamp is plenty of time after it has been fit and trimmed. I like to look at the unclamp time.
