Peeling paint
Home / Forums / Main Forum / Paint and Refinish / Peeling paint
- This topic has 13 replies, 6 voices, and was last updated 11 years, 1 month ago by paul.
I’m currently fixing a peeling hood that looks like it was a new hood. The base did not stick to the sanded primer. I have never seen this before.
I originally thought someone had done wet on wet sealer and didn’t let it flash long enough or let it go too long. I razer bladed all the paint off with ease. I usually don’t razer blade and chemical strip because I find the paint will stick real well in alot of places and you start breaking them and gouging the metal. This hood is aluminum. I did not even use a razer blade holder, just my fingers.I’m really curious what happened. I have seen paint fall off unsanded oem black primer, clear off the base coat, base coat off base coat, base coat off sealer that dried too long as it happened here but never base coat off sanded primer.
[URL=http://s295.photobucket.com/user/Glen440/media/IMG_20150216_0836320731_zps98fd93a8.jpg.html][IMG]http://i295.photobucket.com/albums/mm148/Glen440/IMG_20150216_0836320731_zps98fd93a8.jpg[/IMG][/URL]February 18, 2015 at 7:50 am #48280Just by looking at the pic the substrate looks kinda too shiny to be sanded. If it is a new replacement panel the e-coat might have been lightly scuffed and base applied directly over it which is not recommended.
Wow! That’s crazy! I have seen this on a job we did, on a hood with clear tape. Peeled off the clear tape and the paint came off the spot primed hood. The primer was also sanded. The paint stuck over the spots that weren’t primed. I have no idea what would cause this.
I’ve seen this once before. I believe the sanding paste used to help in the sanding process wasn’t completely washed off. I did an experiment by sanding one side of an old part with sanding paste and not washing it and the other side by sanding with the paste and washing it off properly. When I did a crosshatch test the side not properly cleaned peeled right off. There was no sign of adhesion. The other side never moved. I think it’s a prep issue. IMHO
I still come across painters who believe the finer the sanding the better finish it will produce ,trying to explain that using 1500 when re clearing is wrong can still create arguments ,some sprayers think the scratch will show through the clear which is nonsense ,I DA back with anything from 320 to 600 for re clearing
as for base depending on if it is a solid or a metallic or pearl anything from 320 to 500 DA or 600 to 800 wet n dry ,not that I wet sand much these days
I do a lot of custom work which has high build tape lines so my process is to clear with at least three coats then sand back using the DA with P400 then re clear ,I get absolutely perfect results ,remember all clear is is direct gloss but lacking any pigment and it will cover and fill the same grades as direct gloss pigmented paints will 😉 if basecoat covers P320 DA scratches as recommended by most paint manufacturers then it will certainly work with high solids clears etc
Also the danger is when you dont use a heavy enough scratch over existing clears ,not so critical on fresh clear which will also crosslink but old stuff wont and that is where you will get delam if the clear is sanded to finely
for blow ins I can also use heaver grades but will use a foundation coat of clear base to fill the scratch ,not required for a solid colour but definitely needed for mets and pearls ,if I dont use a heavy grade I will then use P800 on the DA especially for silvers and difficult blends ,darker pearls you can get away with blue murder and I have used P400 on the DA with say Ford panther black
[quote=”ARTSPRAY” post=36810]I still come across painters who believe the finer the sanding the better finish it will produce ,trying to explain that using 1500 when re clearing is wrong can still create arguments ,some sprayers think the scratch will show through the clear which is nonsense ,I DA back with anything from 320 to 600 for re clearing
as for base depending on if it is a solid or a metallic or pearl anything from 320 to 500 DA or 600 to 800 wet n dry ,not that I wet sand much these days[/quote]
Very true, I would not re clear anything finer than at least 800 grit
