Plastic Body panel rivits
Home / Forums / Main Forum / Introductions / Plastic Body panel rivits
  • December 27, 2010 at 4:10 am #26503
    Ok I have like 5 diffrent rivet pullers 3 Pop rivet pullers and an air powered Cherry max puller.
    NONE of them pull these Dang plastic POP rivets at all :cens
    what are you guys useing?
    Im ready to start using aircraft stuff and forgetting all about this cheap Chinese junk
    December 27, 2010 at 4:20 am #26504
    not sure exactly what type of rivets your referring to but the plastic rivets like the ones on chryslers? i use an inexpensive tile nibbler and cut them off. the tile nibbler also cuts the aluminum ones off too if you can access the head slightly. that or drill them out. rivets are a pain to remove but a life saver for installations
    December 27, 2010 at 4:36 am #26506
    December 27, 2010 at 4:41 am #26508
    [quote=”ding” post=16505]http://www.amazon.com/Rivet-Klik-Lok-Plastic-Rivets-MAR48005/dp/B000Q6P9XG[/quote]
    I used to use one like that, and it seems to be the most common one. The trouble I had with it is that sometimes they would jam (and it was a b*tch to un jam), and they made it hard to do rivets in wheel wells due to clearance.
    This is what I have now:
    [url=http://www.sjdiscounttools.com/mar48000.html]Marson Riviter[/url]
    It is super easy to squeeze, fairly easy to get in wheel wells around the tire, and due to the design, almost impossible to get jammed. I don’t know why everyone doesn’t use this one instead. :rock
    December 27, 2010 at 4:49 am #26511
    [quote=”Ben” post=16507][quote=”ding” post=16505]http://www.amazon.com/Rivet-Klik-Lok-Plastic-Rivets-MAR48005/dp/B000Q6P9XG[/quote]
    It is super easy to squeeze, fairly easy to get in wheel wells around the tire, and due to the design, almost impossible to get jammed. I don’t know why everyone doesn’t use this one instead. :rock[/quote]
    I have one of those i got in a kit. dont know if its defective but the teeth wont grab the shanks of the rivot to set them.
    December 27, 2010 at 4:55 am #26513
    [quote=”ding” post=16510][quote=”Ben” post=16507][quote=”ding” post=16505]http://www.amazon.com/Rivet-Klik-Lok-Plastic-Rivets-MAR48005/dp/B000Q6P9XG[/quote]
    I have one of those i got in a kit. dont know if its defective but the teeth wont grab the shanks of the rivot to set them.[/quote]
    Must have been defective…unless the 1 I have was exceptionally built :p
    December 27, 2010 at 7:19 pm #26526
    Hi guy’s
    Thanks for the tool recomendations
    I am going to local jobber today.
    Too see what they have I will let you know what I come up with just might have to order from Amazon though.
    December 28, 2010 at 6:59 pm #26535
    Well I went to my local jobber they had one like Ding was showing so thats what I bought works like a charm thanks Ding!
    December 28, 2010 at 10:03 pm #26536
    dont forget to give me a thanks on the post and bump my karma up a little :whistle:
    December 29, 2010 at 2:37 am #26541
    [quote=”ding” post=16531]dont forget to give me a thanks on the post and bump my karma up a little :whistle:[/quote]
    It doesn’t count when you ask for it… :p
    December 29, 2010 at 3:59 am #26546
    :rofl :rofl :rofl :rofl :rofl :rofl :rofl :rofl :rofl :rofl :rofl :rofl
