Playing with Water
Home / Forums / Main Forum / Gallery / Playing with Water
- This topic has 11 replies, 9 voices, and was last updated 15 years, 7 months ago by nick.
- February 10, 2011 at 5:47 am #28279
Did 2 bumper. one with PPG water and one with RM water. Cleared both with sikkens autoclear LV
[IMG]http://i288.photobucket.com/albums/ll186/paintbyding/p_00373.jpg[/IMG]
[IMG]http://i288.photobucket.com/albums/ll186/paintbyding/p_00374.jpg[/IMG]
[IMG]http://i288.photobucket.com/albums/ll186/paintbyding/p_00375.jpg[/IMG]
[IMG]http://i288.photobucket.com/albums/ll186/paintbyding/p_00376.jpg[/IMG]
and 2 spray outs for my sikkens job tomm
[IMG]http://i288.photobucket.com/albums/ll186/paintbyding/p_00377.jpg[/IMG]
February 10, 2011 at 4:54 pm #28296The PPG lays flatter and isnt as soft when it drys. Also drys a little quicker
February 10, 2011 at 6:45 pm #28300Looks good Ding.
Thats gonna be a mighty fine looking Cougar when your done. Is that gonna be your seekend car??? Maybe something to haul the boys around in if ya know what I mean! 😛
February 10, 2011 at 10:53 pm #28308And your impressions overall of water compared to solvent?…
I remember when we had to start changing over here in the UK. Many said water would be the death of smaller shops, would make the job so much harder etc etc, but several years on (and admittedly, a few generations of product improvement later), and I doubt I would want to go back to solvent base even if I had a free choice.
February 11, 2011 at 2:28 am #28321[quote=”MoCoke” post=18226]my supplier says that most shops who’ve tried the different systems prefer the envirobase or debeer water the most. [/quote]
I can’t recommend DeBeer 900 series highly enough. It is so user friendly that I can’t imagine anyone would have difficulty laying it down perfectly after minimal practice. Designed from the ground up as a water borne product, not a converted solvent or hybrid like many of the early WB I used, and it shows.
Medium to dark colours will cover a 320 DA sanded surface easily if you need to with normal application (‘damp’ coat; one wet coat, final light ‘drop’ or ‘control’ coat), and it dries very quickly to an easily sandable finish if you have to nib out any imperfections.
Sure, hiding power isn’t the best on some colours, but they have a very comprehensive range of ground or under coats which solve that issue perfectly.
February 11, 2011 at 6:18 am #28338sprayed the autowave tonite. Had the reps here blowing smoke up my azz :whistle:
It did air dry pretty quick. I would say a little faster then the ppg. definitely faster than onyx .
Gotta get some tough metallics to try out to get a good opinion of how they really spray and blend out.[quote=”ding” post=18240]sprayed the autowave tonite. Had the reps here blowing smoke up my azz :whistle:
Gotta get some tough metallics to try out to get a good opinion of how they really spray and blend out.[/quote]The Sikkens products are all very good…but as far as the base goes I think the enviro may be marginally better/easier to use than the autowave. But I’ve only sprayed 6 jobs with the autowave thus far…time will tell.
