Poly primer clogging paper
Home / Forums / Main Forum / Paint and Refinish / Poly primer clogging paper
- This topic has 8 replies, 5 voices, and was last updated 13 years, 7 months ago by Mike Murphy.
- January 25, 2013 at 4:49 pm #40597
Hey guys, was wondering if I could get some input on why you think this may be happening. Could be normal for all I know?? Anyway, this is Evercoat 4:1 feather fill poly primer. Sprays out nice and fills pretty decent, but seems to clump up on the paper when you first get after it. Once you have the outer shell sanded off out doesn’t seem to do it anymore. I’m posting some pics, but they may not show very well.
Should add that it had dried for about 24 hours before I started sanding it, and it says it can be ready to sand from 1-3 hours depending on build. This was 3 medium wet coats.
Attachments:January 26, 2013 at 4:52 am #40622Yeah its 3M red. I got at it with some 80 grit first and it didnt do it with that. I will try some purple next time.
January 26, 2013 at 8:18 pm #40647I keep a red scotchbrite pad nearby to scrub off the primer that sticks to the sand paper, it helps sometimes and gets a little more use out of the paper. Also I DA the primer a little first to get that hard to sand film off before blocking.
January 27, 2013 at 5:17 am #40666I have a semi soft brissle brush to knock it off with, or a blow gun. Probably wont be using that primer again though. Doesnt seem worth it.
January 27, 2013 at 8:31 am #40674I absolutely always start with 80. No problems.
I’m finishing off every last sheet of all random sand paper I have and going to Eagle paper exclusively. Their MaxCut paper is the most amazing stuff for blocking I have ever seen.
February 23, 2013 at 11:13 pm #41604Once you get through the “shell” of the primer it doesnt do it anymore.
