primer po
Back to: Introductions2 Replies
Home / Forums / Main Forum / Introductions / primer po
- This topic has 2 replies, 3 voices, and was last updated 12 years, 2 months ago by big daddy.
- October 10, 2012 at 5:18 am #38540
My jobber told me today that they will no longer be carrying all plastic reducer for the CBP sealers and I will have to start using primer po. Read the tech sheet, seemed pretty straight forward but anything I should be looking for? I think that Ben had said something about them discontinuing it.
On small spots and break throughs you can use a little primer po on a clean lint free disposable towel and whipe it on the raw plastic surface. Just enough to wet the surface,do not apply to heavy. This will stop accidently applying (spraying) to much on small areas and possibly getting a lift.
