Question about epoxy?
Home / Forums / Main Forum / Paint and Refinish / Question about epoxy?
  • February 8, 2009 at 7:02 am #12641
    I have got a question for you guys. I have an Accord at work that I am fixing. It is a stolen recovery that I am fixing all over. Most of the damage is little door dings and such. My plan was to go in tomorrow and tape it up for primer. On most of the panels I blocked out most of the dings and added glaze where I needed to. My plan was when I prime it since there are so many bare metal spots I was going to first put down a coat of epoxy, let it flash for 30 minutes then proceed with my 2k primer. Is it ok to put epoxy over top of filler? I am using Duponts chromate epoxy. Would I be better off just using an etch primer? Any feedback is appreciated.
    February 8, 2009 at 7:15 am #12642
    epoxy is fine. you really want to keep etch away from filler or paint. epoxy is an excellent choice for protecting metal. most productions shops would just put urethane over the bare metal.
    February 8, 2009 at 7:25 am #12643
    Times 2
    February 8, 2009 at 8:41 am #12644
    Thanks guys! Why should you keep etch away from filler? I have heard of this I just don’t know why.
    February 8, 2009 at 9:28 am #12646
    The acid in the etch can lift the feather edge of the filler.Same with paint,the factory base coat is not catalysed (sp) so it can lift or ring.I know that many people do it and will disagree with me but I don’t put body filler over paint for that reason.Epoxy is the way to go if you have the time far superior to etch IMHO.
    February 8, 2009 at 10:52 am #12647
    if you have the time …. don’t use body filler B)
    February 10, 2009 at 3:59 am #12660
    Did someone say epoxy??? B) My all time favorite product.. LOVE IT,, great for bare metal, plastics, fiberglass, urethanes, reduced as a sealer, one coat to seal bodyfiller etc etc etc etc.. sticks to anything and everything you dont want it to:blush:
    February 11, 2009 at 2:20 am #12674
    I’ve got to highly agree. unless the Etch primer specifically states it can be used over filler work. Don’t do it…
    I’ve only heard of a few that are actually claimed to be safe over fillers.
