Question for the PPG users
Home / Forums / Main Forum / Paint and Refinish / Question for the PPG users
- This topic has 15 replies, 7 voices, and was last updated 14 years, 11 months ago by Don Wedor.
- September 17, 2011 at 2:26 am #32946
How well does the waterbourne base match to solvent base (Detron 2000)? The reason I am asking is I have to do some repairs to my car and I am worried about the paint not matching. I have room to blend on the 1/4 panel but some of the damage is close to the hood and I don’t really want to get into blending the hood.
Heres the repairs I have to do:The color is a tri stage white.
Any info is greatly appreciated.
ChrisAttachments:September 17, 2011 at 5:50 am #32965Going to be using PPG’s Envirobase on it. I am hoping that it will match against the hood. If not I guess I will just paint the whole car again :rock . Been thinking about painting it like a new AMG tri stage white matte finish.
Thanks Ben and smoothChris
September 17, 2011 at 9:37 pm #329732009 MItsubishi code W13. There is two different colors for that code, 1 is Diamond White and 2 is Silky White. I used the Silky white on my car.
Thanks for the help WydirChris
MIT.W13:10 – SILKY WHITE is a 2009 Mitsubishi color That can only be mixed in Envirobase Not DBC.
The Color code W13 PPG#92961 – DIAMOND WHITE, SILKY WHITE is a 2000 Mitsubishi color that can be mixed in Both SystemsSo these are two totally different colors if you went with the 2009 color your only choice is Envirobase and there are no variants
Formula below for 1 quart base
MIT.W13:10/1
Code Description….Abs. Cum. Grams Parts
T400 WHITE………1173.7 1173.7 1099.8 91.90
T423 YELLOW…….. 79.2 1252.9 74.2 6.20
T409 DEEP BLACK…. 22.9 1275.8 21.5 1.80
T4281 SOLID YELLOW.. 1.3 1277.1 1.2 0.101 Quart Midcoat
MIT.W13:10/2
Code Description….. Abs. Cum. Grams Parts
T490 CLEAR………. 862.7 862.7 808.4 80.00
T453 WHITEPEARL……172.6 1035.3 161.7 16.00
T491 MATT BASE……..27.0 1062.3 25.3 2.50
T4000 CRYSTAL SILVER..16.2 1078.5 15.2 1.50September 20, 2011 at 4:29 am #33021Yes they are two different colors, my wifes 09 Outlander is Diamond white and my Regal is Silky White and there is a big difference. I ordered the paint off of the code on her truck but went with the Silky White so the two vehicles didn’t look the same. I did not know that the Silky white was a 2000 color. I have some DBC left from when I painted my car and am hoping that I have enough to do the repair on my car. If not I will be mixing it in water as the shop I am working at just put in the Enviro system today. Was nice to see the Sherwin AWX go out the door today :rock . Used the enviro on two jobs today and the difference between the two systems is night and day.
Thanks again for the help.
Chris[quote=”ding” post=22522]you are comparing a mitsu color to a gm color :whistle:[/quote]
Who?…. got to remember the car was repainted the Mitsu color
I got my info off the online PPG Colorweb and they both say Mitsubishi.
both current colors PPG #92961, MIT.W13:10
September 22, 2011 at 2:07 am #33049Yeah the door was a large repair area, went from top bodyline to bottom bodyline. Wasn’t much fun blocking that out, my arms and shoulders were hurting after I got it done. Overall the job came out good and the paint matched :dnc. Didn’t get any pics of the repair but got a couple of it in primer and a couple when I just got done clearing it. Take a look
September 22, 2011 at 2:13 am #33051I used what I had left of the Deltron DBC that I had originally put on the car. Just have to wet sand some orange peel off it and polish it back and and it will be hard to tell that it was ever damaged. I am very happy with the way it turned out and can’t wait to get it back out for a drive before I have to put it away for winter.
Chris
