Question for those with PPG Deltron paint systems
Home / Forums / Main Forum / Paint and Refinish / Question for those with PPG Deltron paint systems
- This topic has 11 replies, 5 voices, and was last updated 15 years, 4 months ago by don prcotor.
- November 1, 2010 at 12:13 pm #24864
Hey all,
I have customer with a ’66 Mustang Coupe which needs some paint (blending, not a full respray). He said that when it was resprayed, it was painted in the original ‘Silver Frost’ color, but I don’t have access to the colour formulas for the older US cars.
Can any of you please PM me the formula for 1 litre of this colour in Deltron base coat?
Many thanks in advance!
Cheers,
SimeOK its called Lt. Silver Met (on my system 1966 ford paint code 4 )
Formula in DBC
For a quart
# // Base/////// ///////Color //////////////////////Parts ////////////Cumulative
1- DMD1690///////Coarse Aluminum ///////825.7////////825.7
2- DMD1686 ///////Fine Aluminum//////// ///154.8////////980.5
3- DMD1683/////// Black///////////////////////16.2////////996.7
4- DMD1684////////White////////////////////////7.9///////1004.6
5- DMD614/////////Blue/////////////////////////1.6///////1006.2
6- DMD1609///////Violet////////////////////////0.7///////1006.9
Cost about $74.26 a quart (not exact just close) this is the DBC Formula #32520November 2, 2010 at 4:03 am #24877Thanks Wydir.
PPG must list the tinters with different codes in the ‘states, because my PPG Deltron tinters start with ‘D’, ie. ‘D895 – Colour Blender’, ‘D740 – Black’ etc
Not sure though, because I found this US site that lists Deltron with D codes like I have:
[url]http://usautopaint.com/sitebuildercontent/sitebuilderfiles/ppgglobal.htm[/url]
The Blue and Violet…are they solids or transparents?
[quote=”Paintwerks” post=15076]Thanks Wydir.
The Blue and Violet…are they solids or transparents?[/quote]
Those toners (the D740 etc) are Global toners, the ones Wydir posted are for Deltron. At least that is how it is in all of North America.
November 2, 2010 at 4:37 am #24885Well, that’s confusing! The label on my tinters says ‘Deltron’ and it is referred to as ‘DBC’ here. I did notice that it said ‘Global’ on the label though.
Does anyone have the formula in Global please, and are there any variants or is it just available in a masterblend?
Cheers,
Sime[quote=”Paintwerks” post=15084]Well, that’s confusing! The label on my tinters says ‘Deltron’ and it is referred to as ‘DBC’ here. I did notice that it said ‘Global’ on the label though.
Cheers,
Sime[/quote]Can you post a photo of your toners. That sounds like PPG is labeling the toners differently down there.
November 2, 2010 at 7:04 am #24891here ya go. gobal like you want the dates are for 1995-2008 the code is ford= ts/ brand code 35708 (ppg code) nothing shows up for 1966. and it list 6 alt. to the prime formula. this is for a qt. this is what shows up for silver frost.
abs.——-cum.
D772 CRS. ALUM.— 925.9—– 925.9
D953 CRS. ALUM. —40.2 ——966.1
D759 MATT BASE —-20.2 ——986.3
D959 WHITE ——–18.1 ——1004.4
D966 TRACE WHITE –4.1——- 1008.5
D740 BLACK ——–3.2——- 1011.7
D980 TRANS GOLD —1.6——- 1013.3November 2, 2010 at 7:53 am #24893ok i looked around and found a photo of silver frost 66 stang. the ppg code is 32520 which is the formula that wydir listed. it only can be mixed uped in dbc, no listing for gobal. what i listed above is the newer version of it, and is listed ford ts. the photo i saw looks very close to the new version of the color.
i’ll list the same formula as above but in the dbc version
abs—–cum.
DMD649 CLEAR ——–139.4– 139.4
DMD1687 MED. ALUM.– 374.3– 513.7
DMD1682 CRS. ALUM. –266.8– 780.5
DX685 FLATTING—— 23.9— 804.4
DX821 FLOP ADJUSTER -20.7 —825.1
DMD641 YELLOW——– 2.3— 827.4
DBX1689 CLEAR——- 179.2—- 1006.6November 3, 2010 at 5:04 am #24917i used the online color mix system last night, it didn’t show it in gobal. but then again i was very tired.
anyhow, i hoped we helped him out. - AuthorPosts
