removing epoxy primer overspray from black rubber
Back to: Shop Operations5 Replies
Home / Forums / Shop Operations / removing epoxy primer overspray from black rubber
- This topic has 5 replies, 5 voices, and was last updated 17 years ago by Matthew Smith.
- September 12, 2009 at 1:46 am #15884
Ive got some green epoxy overspray(HOK kp2cf) on the black rubber window weatherstripping on an old Ford.Lacquer thinner isnt removing it.Will uro reducer do the trick? Thanks Great website!
AnonymousSeptember 13, 2009 at 5:12 pm #15906After you chip of what you can you can try touching up the molding with a black sharpe, other then that you a bit on the screwed side. Welcome to the forum btw.
September 19, 2009 at 9:19 pm #16046Just keep soaking it with reducer or thinner and it will eventually come off.. While epoxy sticks to everything and once it locks up its hard to remove, it will come off 😉
