Sanding with a disc sander
Home / Forums / Product Reviews / Equiptment / Tools / Sanding with a disc sander
  • October 25, 2010 at 3:17 am #24618
    Hey guys, I have seen some sanders that look like they are 8″ diameter.
    Can you get the panel straight using a disc sander?
    Looking for a way to help speed up my work.
    What part of the body prep do you guys use disc sanders, at the beginning or after you get your ruff in done?
    This guy wants it to be perfectly straight so I worry about using anything but a long block.
    Thanks for your input.
    Oops, can a mod move this to the proper forum…
    October 25, 2010 at 3:22 am #24619
    u talking like mudhogs???/
    October 25, 2010 at 3:26 am #24621
    :pcorn: Always use a block.
    October 25, 2010 at 3:44 am #24623
    I use an 8″ grinder to remove paint. On the rare occassion that I use fiberglass filler, I will use it to start knocking it down before blocking.
    I use a 6″ DA sander for feathering paint edges and finish sanding (with an interface pad).
    Otherwise, I only use blocks for body work. I personally don’t use air boards or 8″ DA sanders.
    October 25, 2010 at 3:51 am #24624
    shoot i can block all day with an air grinder it all depends on what the customer is paying for :rofl :rofl :rofl :rofl :rofl mudhogs are hard ta beat but an 8 inch rotary can get ya flatter faster if ya hold ur mouth right:stoned :stoned :stoned
    October 25, 2010 at 4:01 am #24626
    [quote=”bondomerchant” post=14842]shoot i can block all day with an air grinder it all depends on what the customer is paying for :rofl :rofl :rofl :rofl :rofl mudhogs are hard ta beat but an 8 inch rotary can get ya flatter faster if ya hold ur mouth right:stoned :stoned :stoned[/quote]
    Not for me…
    I’ve torn the tendon in my elbow twice, so I have a hard time holding onto vibrating tools for very long. When I use an airboard it can get away from me and I either drop it or gouge the filler…more counterproductive and uncomfortable.
    Besides, who doesn’t like the motion of blocking… 😆
    October 25, 2010 at 4:09 am #24629
    Yeah I was talking about the mudhog. I watched the video you made a few mins ago. Seems like it has a large surface to make the panel flat.
    I guess I will stick to my blocking.
    October 25, 2010 at 4:22 am #24632
    i like to use a block for final sanding or to check my work against. it takes too long without a DA or mudhog when u have an entire car that needs plastic work.
    October 25, 2010 at 4:23 am #24633
    [quote=”Jinx” post=14847]Yeah I was talking about the mudhog. I watched the video you made a few mins ago. Seems like it has a large surface to make the panel flat.
    I guess I will stick to my blocking.[/quote]
    dont underestimate a mudhog though they can get stuff flat fast what more could a bodyman want plus my arms can only take so much:chair :chair :chair
    October 25, 2010 at 6:42 am #24643
    Thats what I was looking for… something that I can get 70 80% done and then go over things with a long block with guide coat a few times.
    October 25, 2010 at 7:00 am #24647
    [quote=”bondomerchant” post=14851][quote=”Jinx” post=14847]Yeah I was talking about the mudhog. I watched the video you made a few mins ago. Seems like it has a large surface to make the panel flat.
    dont underestimate a mudhog though they can get stuff flat fast what more could a bodyman want plus my arms can only take so much:chair :chair :chair[/quote]
    Roger that I love my air tools.
    October 25, 2010 at 10:31 am #24664
    [quote=”Jinx” post=14860]Thats what I was looking for… something that I can get 70 80% done and then go over things with a long block with guide coat a few times.[/quote]
    exactly. air tools are great, but they require their own skills or they will end up costing you more time that just straight blocking out of the gate.
    I find for what I do I use a cheese grater quite a bit. I’m pretty lousy at spreading bondo in the first place, and I’m a stereo guy slathering up the filler on crazy curvy little parts. grating it down gets you real close right away, and a blocking with 40 grit by hand flattens things out in a hurry.
    October 25, 2010 at 10:37 pm #24667
    blocking is cleaner and quieter and gets it straighter but for removing a little excess I have used the da before. …. we block filler by hand. :kofee
    October 25, 2010 at 10:59 pm #24669
    I was told to never use a disc sander on large panels because it puts waves so from what i was told its better to use a block on large panels.
    October 25, 2010 at 11:10 pm #24672
    [quote=”Stone” post=14870]blocking is cleaner and quieter and gets it straighter but for removing a little excess I have used the da before. …. we block filler by hand. :kofee[/quote]
    Roger that
