Sata 3000 rp gun adjustments
Home / Forums / Main Forum / Paint and Refinish / Sata 3000 rp gun adjustments
  • January 25, 2012 at 2:53 am #35464
    I am using a Sata 3000rp. No matter what I do the paint always comes out too flat. I have tried a 1.2 tip and a 1.4 tip. I have a 1.3 tip on the way. I dont know what I am doing wrong, but every car I paint turns out looking like an austin martin. This is just completely unacceptable to me, especially when I am trying to paint a Cadillac. I have spent almost $1000 between the gun and the nozzles. Is there any special way to set this up so I get that that grapefruit type texture I am trying to match, or should I just suck it up and buy an iwata :blush:
    January 25, 2012 at 3:47 am #35465
    try painting on a full moon with the lights off when the temp is at 40 Degrees on sunday at 3:47 am :rofl :rofl
    January 25, 2012 at 4:24 am #35468
    [quote=”ding” post=24812]I am using a Sata 3000rp. No matter what I do the paint always comes out too flat. I have tried a 1.2 tip and a 1.4 tip. I have a 1.3 tip on the way. I dont know what I am doing wrong, but every car I paint turns out looking like an austin martin. This is just completely unacceptable to me, especially when I am trying to paint a Cadillac. I have spent almost $1000 between the gun and the nozzles. Is there any special way to set this up so I get that that grapefruit type texture I am trying to match, or should I just suck it up and buy an iwata :blush:[/quote]
    You should just get rid of the RP..as a matter of fact I will take that lump off yer hands and trade you my Iwata straight across… 😛
    January 27, 2012 at 11:18 am #35534
    Ding, I run my 3000rp with a 1.3 tip. Instead of running the fluid wound all the way out (as most seem to recommend), try setting the fluid at 2.5 turns out (from full in/closed), then set your air pressure at 28-29psi with the fan 1/8 turn in (from full out).
    I find the 3000RP great for clearing large jobs (ie full repaints and 2K doors) so I don’t use it that much because I’m not always doing full resprays. For my day to day work, I use a Devilbiss GTI Pro with a 1.3 trans tip (T1 for base and T2 for clear). It lays down lovely OEM looking orange peel and is great to manouver around the detail work. The other painter who works for me also uses a GTI Pro, although he uses the HVLP tip for both base and clear. Both types of tips work really well.
    Hope this helps mate!
    Cheers,
    Sime
    January 27, 2012 at 11:26 am #35536
    i like this one lol
    to get peel
    drop pressure
    do a mist coat of clear as your first coat then a full after flash
    or yeh buy an iwata ! prob a supernova :rofl
    January 27, 2012 at 12:13 pm #35538
    Boy Ding Do ya think they Understand your post?
    January 27, 2012 at 4:43 pm #35541
    thanks guys. i’ll try those suggestions out. 😉
    January 27, 2012 at 11:50 pm #35550
    Ding your killin me :stoned
    January 28, 2012 at 12:59 am #35551
    You know Ding, I would have never figured you had an issue with not getting enough peel :p
    :cheers :cheers
    January 28, 2012 at 2:29 am #35554
    [quote=”ryanbrown999″ post=24890]You know Ding, I would have never figured you had an issue with not getting enough peel :p
    :cheers :cheers[/quote]
    Well ever since I got that urethane wave reducer things have been pretty smooth :p
    January 28, 2012 at 2:37 am #35555
    [quote=”ding” post=24893][quote=”ryanbrown999″ post=24890]You know Ding, I would have never figured you had an issue with not getting enough peel :p
    Well ever since I got that urethane wave reducer things have been pretty smooth :p[/quote]
    i will swap u for ur gallon of urethane wave reducer for some anti solvent pop wipes 😛 😛
