Sata jet 3000 rp digital parts ?
Home / Forums / Main Forum / Paint and Refinish / Sata jet 3000 rp digital parts ?
- This topic has 4 replies, 3 voices, and was last updated 10 years, 5 months ago by Jayson Munro.
Hi folks I’m having a bit of trouble with my gun leaking paint and wondered if anyone has a part number they could help me with ?
The leak is coming from where the pot screws into top of gun itself,when I remove the pot from the gun I can see a White seal at the bottom where fluid enters the gun from the pot so I assume it’s that seal but if anyone has had this issue and it’s another seal then please point in the right direction. I am also in need of a pot lid as mine is cracked and also if there is a general refurb kit available ?Many thanks Carl.
June 28, 2014 at 9:43 pm #46900I dont think there is a seal in the gun body where the pot mounts.Check the bottom of the pot that goes into the gun body is damaged from being dropped or out of round.You can get just the quick connect part for the pot.If your gun body is worn in the mount area the gun is junk,we had to toss a gun at work that was just worn out.Here is a parts breakdown for your gun HTH.
http://www.sata.com/uploads/tx_pxspecialcontent/SATAjet_3000B_HVLP_RP_Parts_us.pdfActually I just looked at the parts breakdown and there is a seal in the gun body where the pot mounts part # 96875 inner cup seal :blink:
Thank you Jason your a star mate,
I was going to post to say that spray guns direct tech guy couldn’t find one so he thought you can’t get them but I had a look at gun and definitely is a White seal in there,
Can you get a service kit for the sata 3000 rp digital or just individual ones only ?
Many thanks again bud,Carl.July 2, 2014 at 6:13 am #46911Happy to help you,if you take the time to look at the part #’s in the parts breakdown there will be a # for a repair kit.Then you can look at all of the seals and purchase whatever else you think you will need,its all right there bud. :cheers
