sealer laid out dry… suggestions
- This topic has 2 replies, 3 voices, and was last updated 13 years, 6 months ago by .
Home / Forums / Main Forum / Paint and Refinish / sealer laid out dry… suggestions
Side of a car. light silver. sealer lays a tad dry. barely feelable when tacked. but can see it. what to do what to do
Depending on what product you used you could wait 30 mins and lightly scuff with some norton foam backed 800 grit paper on the rough areas,tack,and shoot color.Next time use a slower hardener/reducer to make it lay smoother.Could be other variables like your gun,temp,etc.
yea another thing you can try is to over reduce your sealer by 15% and depending on what your using for product you might have to give in two coats but it should lay out as smooth as an egg!
