sealer questin
Home / Forums / Main Forum / Paint and Refinish / sealer questin
  • February 3, 2013 at 8:14 pm #41013
    i am in the process of painting my 2nd car and have a questiin about sealers. the 1st car
    i painted i didn’t use a sealer but figure i will on this one.
    question is, do i get the car into final blocking on primer then shoot the sealer? do i sand the sealer before applying the color coat? if so, what grit?
    thanks…
    February 3, 2013 at 8:18 pm #41014
    After you have finished blocking your primer with 400 grit shoot your 2K uranthane sealer wet on wet to base than clear.
    February 3, 2013 at 8:45 pm #41015
    No. If I have a big chunk or something let the sealer set up for a good amount of time. 45 min or so. Then just nib the prob spot with 600 wet. U will find sealer is not meant to be sanded. It will clog ur paper up right away. And if u hurry to nib it too soon ur going to see t hose marks clear as day when applying base over it. Hope this helps!
    February 3, 2013 at 8:54 pm #41016
    No. If u have a big chunk or something let the sealer set up for a good amount of time. 45 min or so. Then just nib the prob spot with 600 wet. U will find the sealer is not meant to be sanded. It will clog ur paper up right away. And if u hurry to nib it to soon ur going to see those marks clear as day when applying base over it. Hope this helps!
