set up clear gun
Home / Forums / Main Forum / Introductions / set up clear gun
- This topic has 4 replies, 3 voices, and was last updated 11 years, 3 months ago by Dennis Lambert.
- March 31, 2014 at 4:46 am #46223
whats up guys i own an iwata supernova 1.3 clear gun … juss need some advice or tips on adjusting my clear gun wen i use different clears not all clears spray the same or need the same amount of fluid going tru to get good results… right now my gun is set up the way i like it to spray transtar clear 2.1 i can almost juss close my eyes and spray it and it comes out beautiful nice texture everything… am gonna be switching to rubber seal clear 2.1 mix almost sounds like i dnt need to do anything to my gun but i juss wanted to hear from u guys wat kind of tips or tricks, advice u give to set up ur clear gun to get the results ur looking for..
April 1, 2014 at 5:53 am #46242I also use the supernova 1.3 h d for clear. Honestly I almost always spray with full fluid and full fan. I sometimes close the fan slightly when spraying a small part. The main adjustment I do to the gun is air pressure using higher psi for higher solid clears (27-30) depending on the texture I’m trying to match and a little lower for medium solids (24-26). Other than that most of my “adjustments” are done with distance, hand speed, pattern overlap, and trigger pull.
April 2, 2014 at 3:18 am #46251Thanks bro for the tip am sprying rs 2300 clear from rubber seal 2.1… I dnt have a gage on my gun right now i go by noise but am getting a gage tomorrow i will be tryin ur advice see how i make out
April 2, 2014 at 6:08 am #46253I highly recommend the RTI MR1 diaphragm regulator along with a high flow air fitting . This will give you an even pressure and higher cfm. I usually open my gun reg all the way and adjust the pressure at the wall reg. This will also give you a better volume of air.
