setting up a garage paint shop, advice?
Home / Forums / Main Forum / Paint and Refinish / setting up a garage paint shop, advice?
- This topic has 6 replies, 5 voices, and was last updated 14 years, 11 months ago by J’s.
well not really a shop
i just want to be able to work on my own cars…i want to know what materials and shop tools and equipment you guys recommend me. just to paint like three cars.
so far i have:
*devilbiss 6hp 60 gal compressor
*devilbiss gun with 3 tips
*durablocks set,long block,small block,soft block sand papers for each 40,80,180grit
*body filler,putty ect…
*dremel
*pick hammers set and dollies
*wax and grease removal
might have some other small stuff like safety glasses ect..planning on setting up my pipes from my compressor and buying a water trap from home depot.
and setting up a pcv pipe paint booth.
January 8, 2010 at 4:35 pm #18498Might want a D/A.
What do you plan on plumbing your airlines with? Do you have a plan on how to run them?
January 9, 2010 at 9:50 am #18509I would suggest that you look at a Hobart 187 or a miller 211 as far as welders. Air Advantage for a DA and get a true unispotter or the motor guard stud welder. I have the harbor and it does not do as well as the others that i have used.It may seem like more money now but it will be worth it in the end. Good luck with your setup and also check the pawn shops and tool stores if you have any in your area.
thanks i found the air compressor for 200$ on craigslist
i would look around tho…i just bought
*solvent
*gun cleaner
*box of tack clothes
*box of body napkins
*masking paper small roll of 18×180 feet think i might need more??
should i buy at home depot save more money this way?i still need to set up my air lines hopefully ill get this done 2morow and set up my pcv plastic paint booth…
