Sherman William Dimention line..
Home / Forums / Main Forum / Paint and Refinish / Sherman William Dimention line..
- This topic has 3 replies, 2 voices, and was last updated 14 years, 11 months ago by MoCoke.
- January 14, 2010 at 6:43 pm #18621
Anyone out there using the Sherman William Dimension line of single
stages or Finish 1?…..
DennisJanuary 14, 2010 at 7:53 pm #18623Not really had any problems…Price is good and if I do light metallics, Ill base coat with a color thats close that I know will cover…
But,what Im looking for is someone that uses or have used the single stage dimension line…I do very low end paint and need
something that I can get in the range of $100/gal…And be half way decent..Dimension is priced right but Am having problems with it..Dennis
the basecoat is priced at about 100 a gallon too, if you think about it what car ever needs an entire gallon? so throw in some cheap clear and ur set. even if low end paint is what u deliver dont give yourself the headache using single stage. if something goes wrong you have to wait a long time for it to be sanded. with bc you can usually sand within 20 minutes. if not, kirker makes good acrylic enamel and costs so much less. you can buy it cheap online through smart shoppers or auto body tool mart.
