shooting SPI universal clear with a 1.3 tip
Home / Forums / Main Forum / Paint and Refinish / shooting SPI universal clear with a 1.3 tip
  • February 28, 2010 at 3:43 am #19775
    I have been interested in trying SPI Universal Clear but they don’t reccomend using anything smaller than a 1.4 tip with this product—For clear I use a Sata 3000 RP with a 1.3 tip—Im not going to buy a new tip just so I can spray this product when there are other good products out there that work well with a 1.3 tip—Has anyone on here shot SPI UC with a 1.3 tip and did it work well for you?
    February 28, 2010 at 4:03 am #19777
    Im not a painter but i wouldnt worry about it. No two painters are alike, some move fast many passes, some are slower and more deliberate when clearing. Two guys with the same equipment could easily have very different mil thickness readings and appearance.
    February 28, 2010 at 4:08 am #19779
    And if im wrong im sure one of these A-hole painters will correct me shortly 😉 :lol1
    February 28, 2010 at 5:26 am #19784
    its really no problem. i myself have shot atleast a couple hundred gallons of universal clear. mostly all with a 1.4 but i know many guys who use a 1.3 and its not an issue. that clear is so user friendly its not funny.
    February 28, 2010 at 9:54 am #19787
    Get the Ms clear. I prefer it over the Universal….
    February 28, 2010 at 12:20 pm #19789
    I’ve never used that particular product (can’t seem to get SPI over here :(), but I can’t see a problem. The SATA 3000 puts out a lot of material for a 1.3 anyway, so is probably closer to many manufacturers 1.4’s.
    February 28, 2010 at 4:34 pm #19791
    I like the SPI MS clear
    I would try the universal with the 1.3 if thats the only tip I had.
    February 28, 2010 at 8:00 pm #19798
    Han, Doright–What characteristics about the MS make you prefer it to the universal
    March 1, 2010 at 12:05 am #19803
    Smisco The MS and Universal clear both use the same resins, so the quality is exactly the same, however the MS uses one different solvent.. That solvent makes it appear to be thinner, when it actually has 1% more resin content than the Universal.. Also the clear lays down smoother and flows better/longer..
    It is preferred for flow coating by just about anyone who has sprayed it..
    I have only used the Universal and HS that has now been discontinued and basically replaced with the Euro..
    I have some Euro I am going to spray this summer.. JimC has used more SPI than anyone I know of period.. He loves the new Euro and if I am correct it is becoming his favorite of Barry’s clears and he has used them all!!!
    March 1, 2010 at 3:32 pm #19822
    all good clears and i think i am liking the ms over universal now as well. the universal is great for a beginner since it is much harder to run than the ms. bk pretty much covered it. ms is just a little slower for better flow.
    March 1, 2010 at 7:33 pm #19830
    Yup, all good clears for sure. The only draw back with the Universal is that
    it’s super soft. It’s great for garage queens (show cars/bikes) that wont see
    the road too much. Basically it swirls easy.
    The MS on the other hand, wont swirl up that easy. It’s a few clicks harder
    but still soft by any standard. And after cutting and buffing for 40 hours
    or so, it’s extremely nice that it wont swirl up after a wash. On the down
    side, you can get runs much easier as it is very thin (probably good with
    a 1.3 tip). Best not to shoot this in low temps (run city). 75 degrees and
    higher.
    March 1, 2010 at 11:50 pm #19834
    i cant rememebr if i told you this han but there was a slight change in the universal clear activator about a month or so ago so its a bit harder now. its kinda like the euro where it wont fingerprint after 24 hours. i have not used the new activator so i dont really have any feedback on it as of yet.
    March 1, 2010 at 11:52 pm #19835
    Well damn! That changes everything!
