SIKKENS AUTOWAVE best paint gun?
Home / Forums / Main Forum / Paint and Refinish / SIKKENS AUTOWAVE best paint gun?
  • January 30, 2013 at 5:27 am #40825
    Any recommendations for the best paint gun for shooting Sikkens waterborne paint?
    January 30, 2013 at 5:36 am #40829
    Ive used a SATA 3000 hvlp 1.3 for 1 year at 6-7 cars a day. Only complaint is mottling on a few silver cars. Trying to eliminate this. Ive tried SATA 3000 RP 1.3 and helped a little but not perfect. Now im trying a TEKNA 7e7 and I am having better results, but not perfect…..
    January 30, 2013 at 5:53 am #40832
    SAGOLA! 👿
    January 30, 2013 at 5:56 am #40834
    [quote=”gtome” post=29795]SAGOLA! :evil:[/quote]
    Do you have any experience with Autowave and a Sagola? If not try and keep the thread to useful information.
    The Tekna is the best gun I have found for Wave. Quick question, how much are you reducing your tough silvers?
    January 30, 2013 at 6:01 am #40835
    X2 I have been very happy with mine for the last 2 years,I use a 1.4 or a 1.5 when it is super hot out.A close second is an nr2000 1.4.For tough silvers I have had good luck with 40-50% reduction right off the bat after ryan suggested it.
    January 30, 2013 at 6:09 am #40836
    I used a Tekna with the 7E7 air cap and 1.4 tip. Worked very well for me.
    January 30, 2013 at 6:40 am #40843
    I typically reduce 30 percent w
    January 30, 2013 at 6:50 am #40846
    You could try 40-50%,it has helped me in the past.
    January 30, 2013 at 6:51 am #40847
    Start at 40%. On tough colors with mainly DF toner go up to 50% if needed. DF covers very well so it won’t hurt coverage. It makes a world of difference. BMW 354 at 50% is a cake walk.
    January 30, 2013 at 11:21 pm #40861
    [quote=”ryan999″ post=29810]Start at 40%. On tough colors with mainly DF toner go up to 50% if needed. DF covers very well so it won’t hurt coverage. It makes a world of difference. BMW 354 at 50% is a cake walk.[/quote]
    Christ almighty. No wonder I’m struggling!
    I know I’m only smart repairing bit I did the full side on a Ford Fiesta today in Moondust silver (mainly DF)
    I’ve not had any formal training on autowave, just my boss showing me once how to use the program to mix paint. He said to just add a splash of reducer. I bet I’m not even using 10%. No wonder there’s so much texture in the base!
    January 31, 2013 at 1:40 am #40863
    Reduce autowave a min. of 20 percent …. I usually reduce metallic 30 but I’m going to try more as Ryan stated earlier for difficult colors . Andy what system do you use to mix ? Mixit pro?
    January 31, 2013 at 1:43 am #40864
    Except solid colors … Especially ones with 245
    January 31, 2013 at 7:01 am #40878
    I like 15% for solid colors and tossed the “no more than 10% with 245 rule” out the window,any solid blacks I will go 20%,it sprays nicer and isn’t so chunky.
    January 31, 2013 at 7:16 am #40881
    You can add 20% 666 to your 245 black colors before reducing it and it will make it act like the other colors.
    January 31, 2013 at 11:27 am #40893
    I’ve managed to find the TDS and it conflicts with what I was told by some margin!
