sikkens clear coat ?????
Home / Forums / Main Forum / Paint and Refinish / sikkens clear coat ?????
- This topic has 3 replies, 4 voices, and was last updated 11 years, 6 months ago by David Clark.
- June 14, 2013 at 9:30 pm #43393
any one useing autoclear hs +, what hardner and reducer??? bakeing time + temp??? air drying times , wet sand buff times ,any info would be great
June 15, 2013 at 3:58 am #43395Check the tds sheets they are available online :readthis: We used a crapload of HS+ for many years at our shop.We used autocryl rapid hardener,rapid production standard activators with a sata rp 1.4 at 30-32 psi wide open settings.The rapid hardener worked good for us instead of standard hardener as it is slow drying.We still sprayed completes with the rapid and standard and their is a slower activator but can’t remember the name.Also we baked it at 140F for 37 mins.Any othr questions just ask.
June 15, 2013 at 5:20 pm #43398Same here, always used the rapid autocryl hardener even on all overs. I always used the extra slow activator when doing all overs in the summer here. From what I remember it is pretty fast with the rapid hardener and production/rapid activator. Been a while though :whistle: :p
link to tds: http://www.globalsafetynet.com/akzonobel/pdfs/akzo_357_english.pdf
June 21, 2013 at 8:00 am #43436I have been told that in the near future hs+ will be phased out. I switched to hs+ 2 pack a few months ago and love it, I think it’s better than the old HS+.
