Sikkens etch wipes
Home / Forums / Main Forum / Paint and Refinish / Sikkens etch wipes
- This topic has 9 replies, 7 voices, and was last updated 12 years, 5 months ago by daril.
They do a 4×8 sheet in this video.
http://my.twonky.com/video?vid=304983641This is the first I have heard of these wipes.
This eliminates etch primer step before priming or sealing?
Can base be applied directly if there is a cut thru on an edge?January 24, 2013 at 3:50 am #40527[quote=”hating-painting” post=29503]They do a 4×8 sheet in this video.
Can base be applied directly if there is a cut thru on an edge?[/quote]Solvent, probably, WB probably not. Still a good product and far better than mixing up and misting onto those little rub throughs.
Wonder if they’re available in the UK? Will they be any better than aerosol though?
January 24, 2013 at 5:00 am #405329 to 12 sq feet is what is stated on the TDS. About the size of a hood. Temps can affect this. Use it as long as it is wetting the area enough to keep the film wet for 1 minute. if the wipe is too dry to do that you need a new one
You don’t want to basecoat directly on top of it, it needs a primer or sealer. You really don’t want to base over any etch.
any of you guys ever use the RBL version of these? they have a little marker pen for cut thru’s and wipes for bigger jobs…
I had sales guys pushing them on me to stock in my store… the markers seemed kinda cool cuz you could keep it in your pocket…
haven’t got any yet though… not sure if they would be popular or not.
January 24, 2013 at 12:39 pm #40556[quote=”ryan999″ post=29509]9 to 12 sq feet is what is stated on the TDS. About the size of a hood. Temps can affect this. Use it as long as it is wetting the area enough to keep the film wet for 1 minute. if the wipe is too dry to do that you need a new one
You don’t want to basecoat directly on top of it, it needs a primer or sealer. You really don’t want to base over any etch.[/quote]
Yeah, was meaning more for that tiny edge rub through etc, not a whole panel.
Seen a few primer pens that state they will stick to bare metal, but hadn’t considered using them.
