Solvent for gun cleaning
Home / Forums / Main Forum / Paint and Refinish / Solvent for gun cleaning
  • March 23, 2011 at 5:13 pm #29729
    Hey guys I was wondering what kind of solvent should be used to clean a spray gun after spraying acrylic urethane paint? My guess would be an urethane reducer but I wanted to check if there are other chemicals that would be more effective.
    Thanks
    March 23, 2011 at 7:17 pm #29732
    I use Lac.thinner cheaper than reducer
    Unless your useing an Airbrush then Carb cleaner works good without having to take the dang little thing apart
    March 23, 2011 at 7:24 pm #29733
    noob question but what’s a carb cleaner?
    March 23, 2011 at 8:56 pm #29734
    Carb Cleaner = Carburetor Cleaner
    I use Lacquer Thinner tho
    March 23, 2011 at 9:01 pm #29735
    Lacquer thinner
    March 23, 2011 at 9:07 pm #29736
    can you also use lacquer thinnner to thin urethane paints?
    March 23, 2011 at 10:04 pm #29738
    I use Lacquer thinner
    And nope you gotta’ use Urethane reducer for that.
    March 24, 2011 at 2:20 am #29743
    I use the cheapest, most unrefined (lacquer) thinner I can get my hands on, but flush the gun through with a quick squirt of whichever reducer I’m using before putting paint/clear in it. Probably not necessary, but old habits die hard…
