Solvent pops
Home / Forums / Main Forum / Paint and Refinish / Solvent pops
- This topic has 5 replies, 4 voices, and was last updated 10 years, 2 months ago by paul.
With nice flat panels like bonnets and doors it is easy to get the correct paint thickness with your gun distance from the panel and overlap. When you come to guards then it can become trickier because most people spray following the curve of the wheel arch and then go to a horizontal movement once they get above the arch. Very easy to get more paint thickness here and in the curve on the top of the guard as your overlap increases to compensate for a heavy middle because it is closer to the gun.
Depending on ambient temperature an hour flash before clear should be enough but if your base was overly thick in these areas and flash between coats insufficient then solvent pop is a possibility. Other possibilities include reducer choice, force drying of base, air flow in the booth….the list goes on. Really a bit hard to be definitive without having seen the application.
