some quality colour match
Home / Forums / Main Forum / Paint and Refinish / some quality colour match
- This topic has 13 replies, 6 voices, and was last updated 11 years, 11 months ago by Tom.
I’m fighting with a couple colors in transtar at the moment. I have pics of hyundai H5. The left is the only one that comes up in the computer, the right is ford HS which looked good in my dupont color chips. The transtar color decks don’t have any color I have mixed yet, maybe they only have the ones that are close to matching. We had the color scanned and then cross referenced but I don’t have the pic of that one, it was not close at all. I may have made a close enough one at the end of today. Was no time for a spray out.
The other color is T8 ford silver. Its on the blue side and I found some that someone else mixed so I will look at the tints and make my own.
We are trying to get a different paint system to try. I have only mixed one color that was blendable. Good thing I’m paid by the hour and don’t paint alot.
[IMG]http://i295.photobucket.com/albums/mm148/Glen440/IMG_20130123_123330_zps79f1da51.jpg[/IMG]
January 26, 2013 at 5:13 am #40624Well thats kinda how it goes with second tier companies making basecoat. They simply cannot afford or have the resources for color match that the large companies have. The larger companies probably spend more a year on color match than the smaller ones make overall.
Hopefully you’ll find something that works for ya!
fun stuff….. I’ve had many of those issues to deal with in the transtar line over the years. When that happens I usually revert to some old school base that I keep a stash of for emergencies, or if the customer will allow me, I send over some H20. See if your supplier can/will make you a shot of waterborne to put on the car, it will probably match fine and you can move on….
I will have to see if we can get pre mixed water base. That will still have some of its own issues with gun cleaning and waste disposal. There is another low voc system the paint supplier has, I don’t know the name but my boss asked them if we could switch. Supposed to have better color match but more transparent.
I have the whole dupont chroma premier system still, they didn’t remove it but have no binder or reducer.
I have noticed they use the wrong aluminum tint in the colors I have been mixing, all too course. When you use the less course one in its place you get a different color. Its lighter. This was my 2nd time swapping them and had to add a ton of black to compensate.
January 26, 2013 at 5:26 pm #40640A couple tips on tinting, try to avoid killing colors if possible, it causes mud. Its almost always easier to remix and leave some of the color that is troublesome out of the mix. Make a sprayout and add some back in as/if needed.
If you are swapping a smaller metallic for a larger one do not add the same amount in. Smaller metallics cover better and will need less in the formula. Start with half, make a sprayout and add as needed. There will be a color shift when different size metallics are added so it won’t always be an easy switch. The smaller flake will lighten side-tone, and make the color dirtier.
Thanks for the info.
Gonna be a bit of a learning curve to this stuff. Usually first time its mixed they have added a color it doesn’t need and is way off. I did a UJ ford and it had blue where it needed green and the metallic was way course. The first few paint jobs I did here I had my boss come out of the office and tint the colors. They were not any better than what I have been able to do. Getting the color scanned and cross referenced is a waste of time as that color is way off as well.
I only painted as an apprentice and for almost a year a did a bunch of jobs start to finish but still handed most over to a painter after body work. I never had to tint any color, I always found a variant close enough.
I have more been elected the painter as they won’t be hiring one in the near future.
The funny thing with low voc base is you pretty much can’t get a run in it, I tried on a piece of paper with the spray pattern sideways and the very center got a sag about 1/4 inch thick that sagged about 1/2 inch.
Find out what the other system is before you commit to switching. There isn’t much out there in LV solvent that will be any better than transtar. Omni, value-pro,prospray,atx,nason, and dimensions all suck too for color match. Tell your boss to demo some waterborne, and get you into a training course on it
I’m about to dive into valspar’s LV system, I will let you know how it goes, but I’m not expecting anything miraculous. I haven’t found that any of the waterborne systems are bad, they just all have their minor pros and cons.
I would have no issue with water but they have an issue with the booths. I can’t remember how much money they wanted to be spent in upgrades which is really some kind of scam.
I heard they wanted my old work to spend 50grand. Pro spray did a demo in there and only brought dryers and it worked no prob. I don’t know what happened there because the painter moved shops before the laws came in.If I even had a full color chip selection I would be far ahead of where I am now.
January 27, 2013 at 7:52 am #40671What kind of booth do you have?Water will work even in a cross flow booth.Portable blowers will work,you don’t need a million $$$ set up.
We have 2 cross draft booths that draw air from inside the shop through the doors. There is enough air movement to dry the base. I also have time to let stuff flash as its not a production shop. Last week between coats of base I was welding.
Its why I think the paint supplier is trying to make money. I’m sure people spray water in their garage.
January 27, 2013 at 8:04 am #40673Try to find a tinting class it will help out a million and just understanding the color wheel will help.
Your in the gta no? I know a few jobbers up there I can refer you to that will gladly put in a waterborne system. I would avoid prospray, as its missing the color tools and support. I can give you the #s for the tech reps for ppg up that way too if u like.
Water can be sprayed in a garage no problem! And I’m actually about to do that in about an hour!lol
