spies waterborn
Home / Forums / Main Forum / Paint and Refinish / spies waterborn
- This topic has 5 replies, 4 voices, and was last updated 13 years, 11 months ago by randall.
anyone out there swaping to the new spies waterborn? my rep called me the other day talking about the new water base that spies is launching this month, says its the cats pajamas, i know we are makeing the swap sometime early next year, going to be a big change for me ive never messed with water only solvent
SPIES is the same paint as standox 99% I’m sure I’m right.ASK your rep.if it is brilliant stuff.used water base for 16 years .using water base for your first time .completely different ball game.But once mastered its so easy .a walk in the park..It will probably pull your hair out for the first 6 months.
January 11, 2011 at 3:34 am #27025I looked up the new spies base and it looks identical to Cromax Pro.
Hope the color match is better than Cromax
i never used sikkens water there solvent base is awesome, my shop switched from sikkens to spies before i got there, aperently they didnt like the sikkens water, so we are now useing spies solvent but where waiting for the new waterborne to come out and then switch to that, so im assumeing within the year ill have a go at the new spies water
[quote=”PAINTPOT” post=16973]SPIES is the same paint as standox 99% I’m sure I’m right.ASK your rep.if it is brilliant stuff.used water base for 16 years .using water base for your first time .completely different ball game.But once mastered its so easy .a walk in the park..It will probably pull your hair out for the first 6 months.[/quote]
yea man you are right spies and standox…same demon for the most part
