spot repair spray painting advice
Home / Forums / Main Forum / Introductions / spot repair spray painting advice
  • December 25, 2011 at 5:15 am #34900
    hi im doing spot repair on my bumper which has metalic paint and using spray can and wanted to know do i do the blending in after base coat or after clear coat?
    December 25, 2011 at 7:44 am #34902
    Well…
    the best way to repair it is to take the bumper off, repair and prep it then either blend the base (or base the whole bumper) then clear the whole thing.
    If you want to do a spot repair, it will be a lot easier with a paint gun than with an aerosol can. You really need a lot of control (fluid, volume, pressure etc) to get the base and clear to blend out really nice.
    If you are doing the whole thing with an aerosol can, I can’t help out too much. Best of luck to you in any case
    December 26, 2011 at 3:40 am #34905
    Wow, its wierd hereing some one ask if you blend color before or after clear not making fun, just new to me
    December 28, 2011 at 6:14 pm #34927
    [quote=”Ben” post=24282]Well…
    If you are doing the whole thing with an aerosol can, I can’t help out too much. Best of luck to you in any case[/quote]
    :agree
