spray booth air hose?
Home / Forums / Product Reviews / Equiptment / Tools / spray booth air hose?
- This topic has 11 replies, 8 voices, and was last updated 12 years, 6 months ago by Steve Baran.
Yes. You need to use a Non-gasing hose. I would recomend the Permoflex from Sata! They run at 75 bucks. Change hose when you start getting liile blacks hairs or black chunks. They usually last 6 months to a year if you dont bake them.So make a quick detach and when your done spraying take the hose with you.
May 20, 2012 at 5:01 am #36961We have been using the flexzilla hoses http://www.rockler.com/product.cfm?page=26864 and have found them to work very well.We get about a year and a half out of them with repeated bake cycles.
We have also had great luck with wurth brand hoses just for the booth,super flexable,thats what we are using now,over a year and a half and still going strong with no chunks yet :pMay 23, 2012 at 6:44 am #36987Another vote for the flexzilla, (if you can get it shipped to you) And although not absolutely necessary, the high flow couplers make things just that much nicer. I can tell a difference when using them and when not using them.
May 24, 2012 at 4:41 am #37007[quote=”ryan999″ post=26272]I like Prevost or Eaton push lock hoses.[/quote]
Do you have a link or pictures of those hoses Ryan???
May 24, 2012 at 5:31 am #37011Here is the Prevost
http://www.prevostusa.com/proddetail.php?prod=OSTO3835&PHPSESSID=1fb48f3e3dc78d4932b55107d047e051Here is the Eaton. the part number is H20106. It is under the weatherhead name. It takes specific hose fittings that do not get crimped on. They work really well and have never seen one leak.
http://www.jhf.com/catalog_v6/1259.pdf
http://www.qualitysurplus.com/business-industrial/hydraulic-hose/50-weatherhead-h20106-3-8-hydraulic-hose-new.htmlJune 16, 2012 at 8:07 am #37212[quote=”ryan999″ post=26272]I like Prevost or Eaton push lock hoses.[/quote]
If you’re gonna do Prevost, this is the mack daddy.
http://www.prevostusa.com/proddetail.php?prod=RESTO73835S
