Spraying VW LC6M Pearl, advice…
Home / Forums / Main Forum / Paint and Refinish / Spraying VW LC6M Pearl, advice…
- This topic has 6 replies, 4 voices, and was last updated 13 years, 8 months ago by Scott.
- July 19, 2012 at 12:27 am #37656
ok it’s my first bit of spraying really, just a small piece of side trim on a mk4 golf. is there any special way to spray this pearl or can i just paint it like normal base over a grey primer? i’m using lechler water base paint and here’s the mixing code:
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/lech.png[/IMG]
also how much paint do u think i’d need to paint it, just the part on the door, not the small piece on the quarter panel, maybe 3 or 4 feet long, thin, like this:
[img]http://www.gti-bits.co.uk/images/vw-anniversary-large.jpg[/img]
finally on side of the car is a different shade of green than the rest. the side with the part i’m painting is a darker green than the original paint. on my system there is 4 different greens but i don’t have the colour cards to compare it to the car. the guy who previously painted it obviously didn’t either and used the wrong shade, i need to match his wrong shade! or is there any reason why his colour came out darker than the rest?
July 19, 2012 at 11:59 pm #37660i just went for the standard colour, 50ml done it, 2 coats and a drop coat, then gave it 3 coats of clear to give me some room to sand out any dust marks.
first attempt at mixing and spraying my own paint:
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0317.jpg[/IMG]
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0316.jpg[/IMG]
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0318.jpg[/IMG]
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0319.jpg[/IMG]i really need to build a spray booth! the dust is a killer haha! the shed is to big to wet everything lo
July 20, 2012 at 12:54 pm #37668cheers guys, well i just realised that the system tells you if it’s a normal 3 stage pearl so tells you about the 2 coats. this is just a standard colour with pearl tinters so no problem spraying. painted with a devilbiss sri.
July 21, 2012 at 11:07 pm #37682flattened and polished:
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0329.jpg[/IMG]
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0328.jpg[/IMG]
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0327.jpg[/IMG]and here’s the old trim as a colour match
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0325.jpg[/IMG]
[IMG]http://i91.photobucket.com/albums/k299/johnmaloney88/IMAG0323.jpg[/IMG] - AuthorPosts
