STATIC ISSUES…
Home / Forums / Main Forum / Paint and Refinish / STATIC ISSUES…
  • December 9, 2012 at 8:18 am #39768
    I usually check in on this forum every now and then if I need some answers or if I am researching a product so I guess it’s
    time to ask a question. I am having Serious Static Issues in my spray booth and not just plastic parts. I have a Nova Verta
    Downdraft and we recently installed a Direct Fire heater in it. We finally had enough of the oil-fired heater. I called my
    BASF jobber and explained my problem and he told me to throw a chain over the rear of the cars to ground them…. I laughed and
    told him they don’t use solid axel rears in today’s cars. When we built the booth I know for a fact that we did not ground the
    metal chassis. It’s bolted down but that will not work as an earth ground. I was thinking about putting in a few 8-foot ground
    spikes to ground the chassis and floor of the booth. I have been using anti-stat wipes, being real careful with the blowgun and
    my hair still stands at attention when I wave my arm over anything plastic. I know from my Computer Repair Days at NCR that Dry
    Moving Air will cause static…
    I am open to any suggestions that may help me out with this problem.
    Thanks,
    Mark
    December 9, 2012 at 9:59 am #39770
    wipe down with solvent cleaner then waterborne. blow tack and use these last
    http://www.autorefinishdevilbiss.com/Division/DeVilbiss/DeVilbissClean/DeVilbissDeWipeOuts.aspx
    Or do the same steps but put some PPG DX103 in a spraygun and mist some on the panels your painting.
    I like the wipes better simply because they will help clean, you can never have a car clean enough
    December 9, 2012 at 11:30 pm #39787
    make sure when you use the wipes, to wipe in one direction, that helps alot. and the dx103 in the gun is what i do, but don’t use on bumpers, especially on am covers, it spots the am primers.
    but if it helps any, i noticed that when it got colder out, even though i have a heated booth, the static is worse.
    and the whole chain ground thing is a myth.
    December 10, 2012 at 12:14 am #39792
    I remember a product that PPG had over 20 years ago that was called STAT FREE. It was a small 2oz bottle that you added to reducer and sprayed on you parts before you started.
    Sounds close to the product posted above.
    December 10, 2012 at 2:13 am #39801
    [quote=”lild” post=28789]
    [/quote]
    Thats because the air is drier :p
    December 10, 2012 at 2:56 am #39806
    [quote=”ding” post=28803][quote=”lild” post=28789]
    [/quote]
    Thats because the air is drier :p[/quote]you just got’d thank you. :chair
