Textured paint
Home / Forums / Main Forum / Paint and Refinish / Textured paint
- This topic has 7 replies, 4 voices, and was last updated 12 years, 1 month ago by richard elliott.
- November 9, 2012 at 11:54 pm #39017
😉 hey guys, so I did some textured satin black parts for a friend. And know for tomorrow I’ve got a full day of spare time work painting textured parts for a motorbike, and the engine to texture plus a set of rear caliper tops for a car. It’s mad 😉 I don’t understand why there’s a high demand for i ashen its been round for years 🙂
November 10, 2012 at 12:40 am #39018Rikka, I have customers wanting the flat black look. I think it looks like unfinished..I have used SEM brand Hot Rod Black. You would think it covers like a primer, but believe me when I tell you it has to be prepped as if your using base clear. Execpt for the sealer… lol When you say textured … do you mean krinkle, or bumpy, what do you use?
November 10, 2012 at 1:59 am #39019[quote=”billgaino” post=28114]Rikka, I have customers wanting the flat black look. I think it looks like unfinished..I have used SEM brand Hot Rod Black. You would think it covers like a primer, but believe me when I tell you it has to be prepped as if your using base clear. Execpt for the sealer… lol When you say textured … do you mean krinkle, or bumpy, what do you use?[/quote]
Hey yeh you could call it Krinkle it’s more hard wear real good for engine blocks or motor bike frames etc, it an additive which I mix with the clear coat or a solid colour. Ie for if you have a damaged door moulding or a bumper with a lower vallace the you can repair and paint it look original. I will put pictures up so people can see. I’m not kean on the flat look as when it comes to de nib and polish I have to keep ordereing special polish to put the flat look back on
November 10, 2012 at 4:37 am #39024For a flat finish all you need is black single stage mixed with a 100% flattening agent.THis will give you the slight krinkle finish and flat appearance and beats doing base with a flat clear.I use Utech 200 or sikkens Rally black,spies has a rally black also.Much more durable and a time saver,I use it on gm/ford muscle car restorations.
November 10, 2012 at 1:20 pm #39032Hey jayson, yeh I understand what you mean and get that. But for the Krinkle it’s almost like putting fine sand in the paint its weird but looks awesome
November 10, 2012 at 1:29 pm #39034That’s a fine Krinkle on an anti roll bar I did last month
Attachments:November 10, 2012 at 4:51 pm #39040Textured and wrinkle paint are not the same. Wrinkle is obtained through a chemical reaction, texture is not. Texture additve, like PPG DX1999 is added to achieve the desired result. It’s commonly used on dash [i]tops [/i]for GM restorations to duplicate the factory finish. Although many don’t know it’s correct. SEM offers it too in aerosol and gun sprayable but it’s 1K.
November 10, 2012 at 6:12 pm #39044The one I’m using is used to get the paint a texture finish and is sprayed through a gun, not 1k lol :),
Ill rephrase its textured finish on the anti roll bar ha ha 🙂 - AuthorPosts
